I have the following for sale, IN Adelaide SA, can post some items but its up to the buyer to arrange shipping for larger stuff.
17X9.5 +17 Work Emotion XD9's in White with Maxxis MAZ-1 Tyres on front pair and Neuton's on rear pair, Great tread, rims all in good cond, slight scrape on one rim on the outer lip. Will fit on most nissans with Gaurd flaring/pulling or just a lip, depends on camber.
$1800
Whiteline Swaybar package for R32, these are a limited run with 27mm front adjustable and 24mm rear adjustable. you cant buy these over the counter as they are a special order from whiteline. (SAU Groupbuy) normal front adjustable sway bars are only 24mm front whiteline. I am firm on price, they cost me 550 and i havent had them that long. Best handling updrage i did on the car full stop.
$450 with links
264 Degree Cams and Cam gear package. These are direct drop in for an RB20/25. They are regrind RB26 cams from tighe cams. I have spec's of them which can be provided upon serious requests. They come with ISC Cam Gears (needed to achieve the best result as you have to dial them in and tune to suit) these are about 2000 kms old... As new condition.
$600
Thats all for now... i have some other stuff. All parts are still on the car so havent removed yet, however everything can be vouched for.
PM me or email HERE
https://www.sau.com.au/forums/topic/227122-r32-drift-goodies-see-inside/
  • 3 months later...
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
