G'day Guys,
Just wondering if any on in SA has imported a car from Japan through Viktor at IMPORT GARAGE?? Used to be located at Wingfield.. now at Rosewater. Bit of info on him would be good... did u get what u wanted?? any problems??
Cheers!
https://www.sau.com.au/forums/topic/227245-import-garage/
didnt import through him, but he lent me parts to get off defect. Dunno bout him though, in my opinion there are better people to deal with.
Car didnt make it through first time, so i basically had to get all the work done again by using brand new 2nd hand shocks. I wouldnt go back to him if i had my time again.
Edited by R32Abuser
https://www.sau.com.au/forums/topic/227245-import-garage/#findComment-4000761
I have never heard of him where about is he based I an ask some of my friends see if they know him.
What were you looking at importing??
Let me know should beable to help you out.
Cheers gents... on the hunt for a 2000 R34 GTR Vspec... just want the low down on him before i make any commitment.. based on Grand Junction Rd Rosewater..
If anyone can recommend anyone good to Import through would be a help
Edited by Lin33r
https://www.sau.com.au/forums/topic/227245-import-garage/#findComment-4000913
