Custom Coilpack Covers - Gb#4 - Rb20, Rb25, Sr20, Ca18
no problem guys, after Andrew gets back from his trip there will be a 5th group buy up
also, all polished covers were posted last thursday, all powdercoated covers are still getting their coatings done and will be completed and posted very soon!
Hey Bryce, I was going to enter this group buy but got caught up with some other shit so couldn't, but I will be keen for the next one when it's up :P
no problems for everyone interested in a 5th group buy :laugh:
as for this current group buy, i have spoken to a few of you and the packages haven't arrived yet. an email has been sent to AM Performance requesting all registered post numbers (as all packages are always sent via registered post for manufacture and buyer security) so i am waiting for the reply so i can relay the numbers onto everyone involved in this group buy to check if everything is alright on the postage side of things
there has been deadline date/postage issues in the past, which is why i keep links to previous group buys and highlight in the original write up that there may be delays due to the nature of the work, i cant apologies enough for delays of this extent because its a few weeks over due (due to a mixture of reasons this time around) but rest assured that the orders are well and truly on the works and on the way :D
if there are any issues or questions then please don't hesitate to PM me :D
Edited by Brycey
I had a look before, cause I made up the template on this computer but I think it was on an old HDD or something :D
I can have a look at home but I don't know how luck you'll get...
This is from the 2nd group buy, I'm pretty sure I used this
sorry for the slow reply guys
mine turned up this morning, top quality stuff!
d.
glad to hear it mate :)
does anyone have a scale outline of the RB25 cover so i can make a design and send it??
sorry that i havnt gotten back to you about this yet mate, but the picture DRD-00F has posted is pretty much spot on. make sure you keep the design within the center lines :)
Highly recommended group buy :)
also, I only clicked on one picture link and it just happened to be my own coil pack cover! :D
oh you :)
how about a cover to suit RB26?
in one of the previous group buy's i tried to get some modified RB26 covers happening but no one was really interested. i think it was GB#3 if you want to check out the thread (linked on page 1 at the top)
powder covered covers should be in the post by now, just waiting to hear back on the latest :)
  • 3 weeks later...
  • 1 year later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
