Hi All,
Not sure this the right place fore this...but
Almost got hit by a bus yesterday, managed to hit the gutter while swerving to miss it and now the Hicas light comes on. Hit on the left side, light comes on when i start the car, but went away when i made a decent right hand turn. Now its on all the time.
Cars due for a service in like 2000 k's so i'm going to get the mechy to check it out, but i was wondering is it an expensive system to fix? Does it had sensors that i could have knocked around?
Any advice / help is greatly appreciated
https://www.sau.com.au/forums/topic/228011-hicas-playing-up/
yeah, what has happened is it has damaged the seals on the steering rack, with all the hydralic pressure on one side and the wack from the other i wouldnt be surprised if you have bent the steering arm aswell.
it costs an arma and a leg to fix the hicus system. search "hicus lock bar", this will be the cheapest way to repair the damages.
you still need to pull the rack to pieces to fix the seal,
the lock out bar works wonders for the high speed pradictability of the car, when the gtr(and gts4's) break traction and slide the computer counters it by turning the wheels in the same direction the car is sliding to gain traction back, the down fall to this is that the earlier gtr's dont react that swiftly so usually the driver has corrected the oversteer before the ecu has, for example the car slides right, the driver counter steersright aswell, which tells the ecu to steer the back wheels to the left, this gives you that whiplash effect.
with the lock bar in, if the rear slides and the driver oversteers to correct it, the car wont whip lash, it will slide untill the back wheels get traction or you can keep ot pinned and drift the corner.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
