HAHAHA, nice profile pic mate!
You're up for Gold this year too aren't you?
Gold Gold Gold! That picture is supposed to have a copywrite to the Birubi Art R32 so don't know how its managed to sneek in there!
Oh and the Targa weather has arrived, early morning fog, cool with a fair bit of dew...
Ah yeah - the current forecast is for rain every day of Targa. Should be fun! (consequently we are changing over to the softer spring set-up today! LOL)
But Blue Gum are wrapped - they are sure to sell a stack of those expensive coats now!
I bet Blue Gum are wrapped! They aren't the Official event Apparel supplier anymore!
It is now The Targa Shop, which co-incidentally is our MAJOR sponsor this year!
Hahaha - Ooops! :D
And Benny no not that soft. Infact my "soft" is probably where most peoples hard set-up would be.
But then I'm harder than most so you get that. :)
Why does he persist on running them?
because the workshop that works on it is a bridestone dealer (who incdently doesn't run them on his own race car), and it just easier for him that chasing up the Dunlop man.
Whats hard about chasing up Bill? You call and order the tyres, they ring when they are in stock, go down and get them fitted, pay $$$ = Profit! plus 1 sec / km
What does Coop run on the A9X?
I'm on the boat tonght. :)
I'm all packed and ready. The car however isn't. LOL It was still in pieces when I left it late last night but it should all be sweet come 6pm tonight.
I still need to find some helping hands down in Tas (especially for day 5) but hopefully we can find someone friendly enough to help some blokes out.
the YT was testing just the other day, so he should be there...
but then again it is YT!!!!!!!!!!!!
Gave the Road Car a run for Make a Wish at Symmons... Race car still in construction.
Good luck to all taking part. Just had a read of the rules (or lack of) So to make a tip I would have to assess the supercars,
Modern - Vandenberg/Herridge/Close
Showroom - Warren/Daylight/More Daylight
Rest - Usual Suspects
We have 2 x hoists close to Lonny - If you need any help give us a shout
TT984 (09)
Enjoy the Rain... 2003 was a hoot
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
