Hi guys
This might be a really stupid question, but I got to find out as my oil pressure is playing up.
I recently went on a pretty hard cruise, and the day after my oil pressure was really low. Like in between 0 and 2 (idling). Normally it will be at around 2 and 4 when cruising.
It went away for a few day and now it is back again.
I'm pretty sure it is not the gauge being faulty, cause if it is the car will feel normal even if the gauge indicate low. But I can actually feel something different when it is low! In fact it idles even smoother.
I changed my oil before the cruise and I rechecked its level and it is fine.
I don't even know really what does the oil pressure do?! I assuming that its measure the pressure of the oil inside the engine??!! So what can cause the oil pressure to be so low?? I have been using 5-30w oil for a while now and all the other time it was fine, I also change my oil every 5000 ks.
Is there something I can check to find out what is wrong. My car is not due for a service in another 5000ks and I don't really have the time to take it in to the workshop yet.
So any help or advice from here would be great.
Cheers
Skylineakt
https://www.sau.com.au/forums/topic/22819-oil-pressure-what-is-it/
i posted the oil pressure specs on another post have a look there for ur car . remember that pressure will be higher when cold ( oil is thicker) and if u use thin oil it will be lower .that will explain the reson ur pressure was lower after driving hard oil temp would be very high .at idle speed between 0-2 is normal when hot .around 4 is normal just cruising along at 2-3000 rpm ( hot oil ) but remember the oil takes a lot longer to get hot ( normal temp ) than the coolant .coolant temp goes to normal after 3-5 minutes oil may take 30 min .
The pressure was low because ur oil was very hot and thus thinned out ----> lower pressure. I would suggest using xW-40 oil if you drive your car hard!! If your pressure drops very low, just keep the revs up to keep the pressure going...
the R33 factory senders/gauges are notoriously inaccurate. My sender cracks it after warming up and will only read about 3 on in the dash. I have a Greddy oil pressure gauge, and it is much more accurate - reads about 5-6 (kgcm-2) when going for it, 1.5 on idle. If you're worried get an aftermarket gauge.
thicker oil will give u more pressure cause u have more resistance stephen . as i said before pressure will vary depending how hot the oil is and oil takes a long time to get hot unlike coolant that gets hot quick .if u have an oil temp gauge u will notice that .
normal driving after about 1/2 hour it gets to about 110 degrees, if u race the car it will get up to 150 degrees .
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
