so i got my defect letter today and:
ride height too low - bah coilovers - not worried
suspension to retain 2/3 travel - 8/6 springs - should be fine
seatbelt retractors broken - have new seatbelts to put in anyway - not a worry
so far all good...
BUT
INDUCTION MODIFICATIONS to comply with standards
what the hell exactly does this mean?
car (rb25det) has:
hks bling bling obvious turbo & heatsheild
steel induction pipe
fmic
pod (in box with cai)
ebc & all other supporting mods
@ the time of inspection he was concerened with the steel pipe but the physical notice is a LOT more general...
any ideas on what i have to re-stockafy for vic roads (VIC roads)?
https://www.sau.com.au/forums/topic/228193-defect-notice/
yeh I got this too, pretty easy fix... I think it is said somewhere that you can have either a pod OR a fmic... so in basic terms... you can only have one induction mod.... which in this case is obveously going to be the fmic, so just make the pod back to a standard skyline air intake and you'll be sweet...
I got similar shtuff to you... the bs was though, he said he cbf measuring the height of my ride... he just put it down... even when I told him it was fine and to measure it....
prix...
Adam :D
https://www.sau.com.au/forums/topic/228193-defect-notice/#findComment-4014939
prix...
I would have shoved him under the car, ruler in hand.....cbf is no excuse, he could get his arse fired for that. Essentially by writing that down he's given false evidence on a legal document.
https://www.sau.com.au/forums/topic/228193-defect-notice/#findComment-4015040
I had to customise My original air box to fit back in....
I made it look like it was meant to be that way....hacksawed it up, then black electrical tape where is had cut and a quick spray of black paint :P
If you have the standard filter in it like mine did.... don't flog it, car feels like its chooking and will be jerky... or you could just buy a better panel filter... but I cbf wasting the money for a drive down to the mechanics.
I know of an awsum place in Dandenong that told me all was good except for my hid kit... instead of making me pay again and have to come back, they said that I could work on it there, offered me standard bulbs if I needed and said that aslong as they see it leave with standard bulbs then it is fine...they also didnt say anything about my bigger turbo or bleed valve :laugh:
https://www.sau.com.au/forums/topic/228193-defect-notice/#findComment-4015766
i use to use a rwc guy that didnt fill out a rwc on the first check so if you needed longer to fix it you could, he would also only charge for one inspection, unfortunately he has retired.
https://www.sau.com.au/forums/topic/228193-defect-notice/#findComment-4015972
Having a POD and a FMIC is NOT a defectable offense!! It is an EPA issue, all the police really should do is EPA you for having both. As long as your POD is well secured, they should not be able to defect you. In fact if you come to my workshop with both your POD and FMIC, providing the POD is properly secured it will not get picked on.. AND as long as your intercooler has been mounted without and modifications to the cars structure, as in cutting structural parts to fit cooler piping etc
It just might be worth trying to get in contact with the people who are in charge of or handle the RWC side in VICRoads. I only know this because my bosses have attended roadworthy workshop meetings and have spoke to people higher up in VICRoads, and they have all said if the police have a problem with it then contact them!!
But then again getting EPA'd sucks! But if the police cant find 3 defects you dont need to present VICRoads with a RWC!
https://www.sau.com.au/forums/topic/228193-defect-notice/#findComment-4016002
where abouts is your work shop, with a comment like that im sure you will get more business in the near future.
Also there has been some spectulation lately that the hole for ic piping is only illegal on S2 R33's due to the air bags, do you agree with this?
So i guess it is best to come and see you for an rwc and not mention the epa loop hole.
https://www.sau.com.au/forums/topic/228193-defect-notice/#findComment-4016008
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
