depending on how much has been taken out i hear its a pain in the ass.
mine had the power steering lines to it pulled aswell and when i went to nisswreck they said id be looking at 1k in parts alone
if its for a defect engineers report for hicas lock bar was 1400 which is the option i took as recommened by the nice guy at nisswreck. fd up but its good to say to the cop pulling you over "yeah its all legit i got a e report in there if you wanna read it" the usual reply is free to go sir as they cant be fd reading it
Edited by Inline 6
https://www.sau.com.au/forums/topic/228274-hicas-system/#findComment-4016149
1G. wtf
thats only one prob i need to fix for regency. hopefully it aint been taken out fully.
I heard it weighs around 25kg all up so I thought it may be alil expensive.
what about standard boost control solenoid.
standard front castor rods.
This is f**ked. im moving house this thurs. now I have to tow the car there.
https://www.sau.com.au/forums/topic/228274-hicas-system/#findComment-4016164
If the car defected is the car in your profile, an R34, you should be ok as if I recall correctly the 34's and 33's share the same HICAS system, electic not hydraulic like the 32's. Should just be as simple as finding someone with a spare HICAS rack and swapping it in. Keep in mind you're probably gonna need a wheel alignment after all the stuff is switched back too!
https://www.sau.com.au/forums/topic/228274-hicas-system/#findComment-4016185
Heslo. yeah I read that b4 too. wasnt sure if it were correct. sounds right tho..
wonder how long it takes to put back in tho
and yeah its out of rego, so deff a tow me thinks.
https://www.sau.com.au/forums/topic/228274-hicas-system/#findComment-4016196
i was in the exact same situation, needed to go through regency and had a lock bar in, lucky i had a HICAS system sitting round the place, but im sure ud be able to find someone whos got one laying around, most people get rid of the things as soon as they can.
btw, what i did was lock the system up with washers, it meant i didnt have to reconnect the lines and get it functioning again.
https://www.sau.com.au/forums/topic/228274-hicas-system/#findComment-4016537
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
