Car Finially On The Road Again
Guest INASNT
After over a month of my car sitting at ice with problem after problem i finially get to drive it again, YAY!!!
The 550cc sard injectors, 044 pump, z32 afm, Power Fc, Greedy Profec B Spec 2, 9 Puck Cermaic clutch with 1200kg pressure plate, Lightened 4.5kg Chromemolly flywheel, Pineapples and Adj HKS Cam gear are all in and had a light tune with the Power Fc and got around 185rwkw@12psi .
The new custom made 3037S with 45mm external wastegate and custom high mount exhaust manifold are going on in the next few weeks. Same guy making my turbo as who made leewahs.
First with the exhaust cam gear set at -2.7 degrees, the profec b spec 2 setup properly with the pfc tune and lightened flywheel I am getting 12psi by 2000rpm!!!. Secondly the new clutch is farking heavy as and the friction point is mm off the the floor which means i have to rev to about 1500rpm before i can take off or else it stalls, so if i take off at 1500rpm, 500rpm later i have the full 12psi boost kick in. Not fun at all in the wet as I come off the clutch at the lights with the wheels already spinning before i even start to move. Should be more drivable when the new turbo setup goes on.
I recommend the lighhened flywheel to anyone as even tho i got the same peak rwkw as before with the ligtened flywheel and pfc tune it accelerates just so much faster and i got soooo much more midrange power now than before.
Will keep updated when new turbo setup finially goes on.
https://www.sau.com.au/forums/topic/22833-car-finially-on-the-road-again/
  • Replies 42
nice..nice! that 3037 might just stretch those internals a bit too much though I have a feeling..
u should take it to Calder before they put the new turbs on...
Pity I have given up the mod-chase with mine anymore... my next project I have in mind however should give u a nice little run in those tropics :) I'll only need about 230-240rwkw to match you too..
Clutch will wear in and be nice .. at first they're a bitch... the last owner of mine changed it recently before he sold it. For the first couple of months was a pig to start, esp in the wet! it was either stall or spin stupidly..but it sorted itself out.
Guest INASNT
meggala
I been driving around automatic hire cars the last few month so any clutch at the moment would be hard i guess.
The 3037 i am getting will be
Comp
56 trim/57.0 Inducer / 76.2 Major. Hosing - 0.6 A/R
Turbine
Wheel 84 Trim - 60 major /55 Exducer
Housing 0.87 A/R
Robos
What power did your car make?
Gordo
I hope it looses a bit of its bite. And yes we should try go to Calder again but i am flying back to cairns on wednesday morning and returning friday morning. Fark i been over in cairns more in the last 3 months than been in melbourne, and the roads up ther west of cairns about 200km are just dead straight for about 5 km's in stages, its so tempting to just go full throttle.
As for the internals i have already scoped prices on weisco forged piston/rings and rods, mild ported head work, 1.6mm HKS head gasket and 260 duration intake/ext Tomei cams. They cost a bit but not 2 unreasonable.
Grim
U cant change the intake side with cam gears as then u will loose the nivac. I should be able to retard the timing to about -4 once the new turbo is setup and a bit more time is spent tuning the pfc. The exhaust cam gear, profec b and the pfc tune helped i recon the boost to come on so low plus its a series 2 so it uses the so called plastic comp wheel.
Guest INASNT
Originally posted by Grim
Denham....are you working your car up for the track or the drag strip? How many times have you had it on the track or run it at the strip?
Most prob drag strip, as not much track action goes on here in mel
Pic of the casing, u think there will be much lag?? :)
Guest Robo's
Originally posted by INASNT
meggala
Robos
We got 178rwkw peak, didnt want anymore plus the stock cooler was heating up, last run was 172rwkw with a little less boost. This was during SAFC tuning.
Feels so much better
Hey Denham,
Seems like the guy working on your turbo does look like the same guy who did mine ;) Good work on it all mate. Your car almost became part of the furniture mate. Pity you didn't have a huge spoiler, I wanted somewhere to put my Maccas the other day :D
I got Nittos if you wanna buy some.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
