any news 'boostdR' about your choice with turbo setup? how did u go with the gtrs v's 618z?
i am looking at the same thing & possibly building up an rb30 with 618z's (my current gtss setup will be too small for an rb30 if i take this path)
  • 1 month later...
  • Replies 107
Posted Images
  • 6 months later...
im not sure where matt is up to but ive got my setup running.
my 'forklift' rb30 (tongue in cheek dirtgarage lol) with garrett -10's made 270.9awkw @ 6500rpm on 10psi, rich run-in tune.
final tune is booked for next week :) very happy with results thus far
i posted a thread here with dyno graph if u want more info: http://www.skylinesaustralia.com/forums/Pr...la-t277399.html
  • 1 year later...
Hi all,
I ended up with a 89mm sleeved bore rb263# ?? HKS GTRS turbo's, E85 and 8.7 to 8.8:1 Comp for E85. I have had it on the Dyno for a initial tune. Maxed the fuel pump out @ 534kw and 20psi. I have a new fuel pump now and will install and get it happening.
Will be playing with the ingnition trasition onto boost and the cam gears for some extra response. I am using Stainless Mani's but may see if the 6boost ones fit without having to move all my lines.
Matt
Before and after. Similar response with more power
For those wanting to know if the HKS version of turbo is better. I can say they still surge slightly when loading up on boost in a high gear/low rpm...sound like a Cho cho train. I have no BOV's. Installing the std BOV's would prob fix most part throttle surge...but it's very minor and doesn't bother me.
Edited by BoostdR
Me personally, I'd go for HKS GT-RS twins interestingly. I'm not arguing with what your tuner says - but if I had not heard that and for some strange reason I wanted to go for twins at that power level, HKS GT-RS would be floating around the top of my list. Going for under 272deg duration is probably not something I'd do when going for turbos that size/power that high however.
The CAMS I ended up using are much smaller than 272 with just under 10mm. They work extremmely well. The Prelude was that we actually ordered a set of JUN 272's for a customers track GTR with -10's but by mistake got the lower duration and figured we will give them a go...results were very impressive and suprising to say the least.
Hi all,
Matt
534kw YIKES!
u make me want to switch to E85 sooner rather than later! with that fuel u should be able to run 30psi without a problem.
is this power reading rwkw, awkw or engine dyno?
amazing power from the good old low mount setup, congrats :P:):P
that 380kw is a lie, check out the intake temps of 63degrees,
lol, agreed. Not sure what the correction would be. I have other graphs for 372 @ IT of ~21degree's
good spot
I more put it up for a Curve comparsion
534kw YIKES!
amazing power from the good old low mount setup, congrats :P:P;)
It's at the Fly Marko. Was 457kw at the wheels.
Fuel setup currently is a GTR pump and single 044. I have another 044 to go in. Injectors(1000cc) are pretty much out of flow already even with my high rail pressure.
haha, atleast u admit it lol.
when are you taking it to test it at eastern creek
I don't live in Syd anymore. I'm in Adelaide. Will be at Mallala this weekend.
Will be Pit Crewing at Eastern Creek on the 3-5th of Sep. Might bring it up to WSID on the truck.....May need a couple of spare gearboxes...
When will be you be at Mallala on the weekend, weather permitting I guess? Would not mind coming to have a look if you wouldnt mind...
that figure of 457awkw is aligned with what my tuner advised i could achieve if i switched to e85.
what exhuast diameter are u running?
Will be there on Sat. All day
Come say Hi.
Matt
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
