that figure of 457awkw is aligned with what my tuner advised i could achieve if i switched to e85.
what exhuast diameter are u running?
That was at 20psi... will update when I get some more fuel flow
Exhaust is twin 75mm into 90mm-100mm(not sure). Center muffler 90-100mm and 5" internal rear round cannon. Primaries are long....past the gearbox up to the uni I think. No cats
  • Replies 107
Posted Images
Did I read that right back on the previous page where you said 89mm bore?
Based on my experiences with machining and sleeving RB26 blocks, the outer diameter of the cylinders tend to break away when bored to 92mm which is the necessary bore size for the OD of the sleeves.
Admittedly I only have a little RB30 experience but does the RB30 block have thicker cylinders, say around 94-95mm? If so they would support a dry sleeve very easily with an 89mm bore.
Or have you done some very radical work in order to allow the block to support a wet type sleeve? I investigated doing this as well with the 26 block, and Darton told me the block wouldnt support a wet sleeve and retain good strength (I presume unless extra measures were taken). I guess with enough grout filling the block would become sturdy enough anyway.
I had thoughts of using a stepped sleeve, that is say 95mm OD at the top, and then 92mm from 1/2 way down the sleeve to the bottom. The theory being that this would give the cylinder strength where its needed, close to the combustion chamber end of the cylinder. While keeping the block intact enough to not compromise the bottom end rigidity. Then with a 1/2 grout fill it would still be pretty much bullet proof block, and support an 89mm bore.
Sorry this is off topic, but you seem to have solved your turbo choice situation... and you have a very interesting engine that provokes me to think of ways to add more capacity to the RB.
Edit...
89 x 87.7 = 3275cc!
Edited by GTRNUR
Had sooooo much fun at Mallala. Was happy to know that the car was faster in some parts than the Lamborghini (very similar straight line but faster in the twisties)
search youtube for : Mallala 14th Aug 2010. R33 GTR RB26/32DETT 716hp playing with Lamborghini
S**t I am surprised you even went out... the weather kept me away!
weather was horrible in the morning but dried up for a couple of sessions. I have some in car footage but it doesnt look to great. time to invest in a better camera i think
sounds nice & beefy!
if u get any more footage, pls add it to your thread
Keep the thread updated as to when you are heading out to Mallala again.
Good effort.
Will do, In all I was happy with how the car performed. I'm off the Collinsgrove Hill Climb on the 28th Aug...will be fun to get some anti-lag launches happening. I cracked a disc rotor yesterday at the track so looking at my options atm...
Not sure on what pads. Want a street/track pad. Obviuosly the best of both worlds...no squeal, low dust, low wear and high friction CoE..
Hawk DTC 60-70? may be noisy
Very nice setup & power BoostdR .
Have you looked at the Endless MX72 pads.. they seem excellent in my short experience with them, no squeal from them , excellent bite from cold & hot ..low dust.
The Angle on the Camera is not optimal, but here it is anywho
I went with Intima SR pads which are also a dual purpose street/track pad. Also grabbed some DBA slotted rotors, including pads $599
NON METALLIC ORGANIC ARAMID FIBRE MATERIALS (DON'T CHEW INTO ROTORS)
High thermal stablility from 0 to 700 degC !
Average 0.4µ to 0.5µ@ 700degC
Typical application: Performance Street and Circuit Track use.
LATEST TECHNOLOGY MATERIALS
These pads are formulated to take a thrashing. Made from extreme temperature, organic aramid fibre materials that don't chew up your disc rotors.
Intima is one of the largest Performance Brake Pad Suppliers to the Japanese Market. We stock a range of Street Race Series performance brake pads for Japanese and European performance vehicles with better specifications & performance as other big-name expensive pads but at much less cost.
One thing to note about cars; they are like women in many ways. Single, hot, sane - pick only two.
Quite the same with brakes really. Your not going to get something that works great for both street and track that doesnt squeal/eat rotors/have low dust. Pick two, be done with it.
For me brake dust is like war paint :D When real drivers see an immaculate car with crazy brake dust they know you mean business. My fav was washing the car the day prior (exhibiting some pride) and being told off by the old man for the amount of brake dust and bug guts the next morning :P
+1
Not to mention the semi slicks with the rubber that looks like its been boiled!
For me brake dust is like war paint ;) When real drivers see an immaculate car with crazy brake dust they know you mean business. My fav was washing the car the day prior (exhibiting some pride) and being told off by the old man for the amount of brake dust and bug guts the next morning :)
haha, I like it. Unfortunately I have had the squeally pads before and absolutely hate it...must be getting old(32). I would prefer to replace the pads more often to be honest. I will let you guys know how the pads go and update you and on the Brakes/Suspension thread.
lol u remind me of my mate with his mazda mps - he dumps the clutch all the time & i ask him why?
to be honest ive never seen anyone do that in gtr whilst rolling, on launch im all for it though ;)
sounds tough :)
Edited by Marko R1
+1
With their remains scattered from the budflaps as far as the bootspoiler.
Life at its best ;)
Sorry OP, back to topic!
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
