GOR Casualties...Late but here..
Guest RedLineGTR
Well after a nice monday, i come home to see a letter on my table...i wonder to myself what it is and i open it and i find a nice blue letter. OH great thats all i need to start the week...it was from the GOR cruise and thank god it's only that much, they must of caught me in one of the towns or something. No idea where it was. Good we wernt speeding on the road i was unlucky. All the high speed runs we done on a old airfield it was nice, so we kept to the limit on the roads, oh well shit happens more money to waste.
My Nice peice of paper
:D;):D :D
https://www.sau.com.au/forums/topic/22852-gor-casualtieslate-but-here/
64km/hr hey.. you're a danger to all sane people and are going to kill somebody anybody any second with those 4km/hr over the limit... Thats pretty rough though :D Although those zones will soon be 50km/hr give it a few months.
I'm glad I wasn't driving now. Wonder how many others are going to recieve a similar notice?
Guest RedLineGTR
omg i'm going to loose it going over 4km/h...quick i'm a menace to society...Yep Victoria...Steve Bracks you Poof...
Oh well i assume if anyone else got one they will get it within this week. Oh well only abit over didnt go much over that speed while on the cruise, i guess just bad luck. Eh :D
3km/h over and you're booked!
I SAW THAT CAR!!! It was a Magna I think, with a camera box in front of the bumper, people from other direction been flashing on us, and I stomp on the brake, hopefully when I pass that car my speed didn't creep over 63km/h... very tricky.... finger cross...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
