It will be hard for the cops to do anything for him if they opened an account with false details. Depends on the money lost too, I mean if you lost a few hundred the cops will be like yeah we'll deal with it and put it on the bottom of the pile. If he has lost $$$+ then maybe they will go all out, it might have happened to others too etc. It's just a shame because it happens all the time. f**kers. I hope you get some action man.
What happened exactly anyway?
https://www.sau.com.au/forums/topic/228580--/#findComment-4020887
i lost $4000 from this dickhead. wasnt able to get anything back. apparently he doesnt even turn up when summoned to court... theres been a few guys that have been burnt by this mob.
they are in sydney, i did have a address. which was just a random house i think.
https://www.sau.com.au/forums/topic/228580--/#findComment-4021583
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
