Item:2002 200sx S15 GT Spec wheels and tyres
Age:6 years
Condition:3 are still like new but 1 of them has a scratch about 5cm on it
Price:$500
Contact:PM BEST
Comments:Im selling my brothers S15 GT Spec wheels for him.
They are like new but 1 has a scratch on it
The price is not nego. since 2 of the wheels have new bridgestone rubber on them.
The other 2 are fairly worn down!
Will send at buyer expense
Thanks
https://www.sau.com.au/forums/topic/228627-s15-wheels/
Hi mate,
S15 rims are 16 x 6.5 to my knowledge; same as S14/R33 stockies. Your set are in good condition also. But honestly, (and I'm saying this to help you out with the sale and not being an A-hole), but you've overly priced the rims, EVEN if it's got 2 new tyres. Most sets range anywhere from $90 the set (with worn tyres) to $300 with new tyres. Have a look on nissansilvia.com and hope it will help you with the sale and give you an idea :ermm:
Goodluck =)
https://www.sau.com.au/forums/topic/228627-s15-wheels/#findComment-4052870
Thanks guys for the feedback
But the tyres alone are worth $320 for two!!
They are Bridgestone tyres and werent cheap!
So realistic you are only paying $180 for GT SPEC wheels!
Also they are not normal 200sx wheels they are the shadow chrome ones and there werent too many
https://www.sau.com.au/forums/topic/228627-s15-wheels/#findComment-4072517
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
