Yep, sounds like the heater core. Any radiator place should be able to get/make you one up. There are plenty on threads on here about it and how to replace it. It's a big job though as the whole dash and heater box need to come out to replace it. It's cheaper if you can do it yourself.
ok thank people i have joined the hoses togeather already...
could someone chuck some links up for me on the heater core replacement
also what the best way to clean this carpet so the coolent cant stuff it
just bought a new core from a NATRAD shop - $275
thanks for the help so far peeps..
where in melbourne can i get a new heater core where there already pre made for this problem rather then getting someone to make one up for me???
cores premade at a radiator repairs shop
sorry not just the core i want premade the whole thing is what im after
that is everything, only thing they dont come with is the 2 plastic tubed sections, you need to re-use the ones on the car now - each held on with 4 litle screws
unfortunately i think i have the same problem, had this happen in my old na fairlane, was told it was a big job so i went and got a quote to do it as i cbf, went to 3 places, 2 straight out said they dont wont to do it and the other quoted me $1100.
ended up selling the car to a mate, took him 2 full days although he did have to do it twice since he left the plug for the hot/cold door off and ripped everything out to do it again, once he had everything out he realized that it was just a plug under the dash pad.
now i have to some how convince him to do the 33.
try nissan, you might get lucky and that part is used for other models, when i bought the one for the fairlane i got it from bursons.
where abouts in melb are you, i have access to a trade account through bursons, ring and see if they have one if they do i'll get a trade price.
i paid $365 for a genuine nissan one back in 03 - let me know if you want the part number
If they are that price probably better off pulling the old one out and having it cleaned and repaired.
read a few posts up, they can be had cheaper - im not sure why i keep replying to this thread though.
if you have seen these cores and how they are setup, there is no fixing them
NATRAD radiator shop
$275 - alloy core
$345 - copper core
NISSAN
$365 5 years ago
the info is there, by all means try to get it fixed, but it would cost more than just getting another core.
for the cost of 3 tanks of fuel - you get your heater back in the middle of winter. up to you i guess
300zx use the samer core just the screw on plastic outlets are diffrent . just buy a new one from a natrad dealer they are a prick to change i did my sons .
there is no way i would go thru so much work to use a repaird core or a second hand one
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
