Yep, sounds like the heater core. Any radiator place should be able to get/make you one up. There are plenty on threads on here about it and how to replace it. It's a big job though as the whole dash and heater box need to come out to replace it. It's cheaper if you can do it yourself.
ok thank people i have joined the hoses togeather already...
could someone chuck some links up for me on the heater core replacement
also what the best way to clean this carpet so the coolent cant stuff it
just bought a new core from a NATRAD shop - $275
thanks for the help so far peeps..
where in melbourne can i get a new heater core where there already pre made for this problem rather then getting someone to make one up for me???
cores premade at a radiator repairs shop
sorry not just the core i want premade the whole thing is what im after
that is everything, only thing they dont come with is the 2 plastic tubed sections, you need to re-use the ones on the car now - each held on with 4 litle screws
unfortunately i think i have the same problem, had this happen in my old na fairlane, was told it was a big job so i went and got a quote to do it as i cbf, went to 3 places, 2 straight out said they dont wont to do it and the other quoted me $1100.
ended up selling the car to a mate, took him 2 full days although he did have to do it twice since he left the plug for the hot/cold door off and ripped everything out to do it again, once he had everything out he realized that it was just a plug under the dash pad.
now i have to some how convince him to do the 33.
try nissan, you might get lucky and that part is used for other models, when i bought the one for the fairlane i got it from bursons.
where abouts in melb are you, i have access to a trade account through bursons, ring and see if they have one if they do i'll get a trade price.
i paid $365 for a genuine nissan one back in 03 - let me know if you want the part number
If they are that price probably better off pulling the old one out and having it cleaned and repaired.
read a few posts up, they can be had cheaper - im not sure why i keep replying to this thread though.
if you have seen these cores and how they are setup, there is no fixing them
NATRAD radiator shop
$275 - alloy core
$345 - copper core
NISSAN
$365 5 years ago
the info is there, by all means try to get it fixed, but it would cost more than just getting another core.
for the cost of 3 tanks of fuel - you get your heater back in the middle of winter. up to you i guess
300zx use the samer core just the screw on plastic outlets are diffrent . just buy a new one from a natrad dealer they are a prick to change i did my sons .
there is no way i would go thru so much work to use a repaird core or a second hand one
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
