The first thing I did when I got my car was remove the Autometer boost gauge. It was on the steering column and blocking the view of my tacho redline, which I thought was a much more important gauge! It had the EBC and it was all set correctly, so I really didn't need the boost gauge. I used the factory gauge as a rough measure of the boost and it was fine.
But later as I started ramping up the boost towards 15psi and past the limit of the factory gauge, I decided to put the Autometer one back in. Only out of curiosity's sake really, to see at what rpm what boost is made. I find it WAY too difficult to look down at the EBC's digital readout, it's so far down (below the radio) that I would even say it's dangerous to keep an eye on while driving.
So I put the boost gauge back on the A-pillar. Probably defectable, but it won't be much skin off my nose if I have to remove it. I have to say though, with the chrome cup it looks quite neat from outside the car. But that's not the reason I put it back on.
All other additional gauges can wait. So I'd have to say that no aftermarket gauges are important to me. ALL of the factory ones except boost are important!
Defi look the most awesome.... but I would only put it on the a-pillar... but thats illegal :P
Tell me, has anyone been defected in melbourne cos they have gauges on their a-pillar?
Comeon, almost all Skylines I pass in Melbourne have SOMETHING stuck onto the a-pillar.
I don't get it. Taxis get to have whatever they want on their dash - their ID badge, stickers, bits of plastic, pen holders with pens in them, electronic/radio stuff, but we can't have a single gauge?
Maybe combined with the lack of compulsory seat belts for taxi drivers they will be instantly killed by all the crap on their dash in an accident and thus be less of a burden on our health system.
seriously but they only obscure ur vision by like a couple of cm's, gosh man y does the aus govt they take these things so seriously its not like someone is gonna die because a driver had a rev gauge that obscured his vision.....in the USA the 350Z came wif drilled aluminium pedals but ova here ive heard nuthing of that feature......full on ****ed
you can have as many guages as you want. if you know what it does and this effects your vehicale, i say go mad. i did.
craz0 i have the apexi turbo timer which have the factory air flow setting displayed. im yet to compare to a tuning sensor so i cant honestly tell you how close it is.
I'd have to agree with Merli.
I've never ever once looked down at my boost guage (center console below my mp3 player) while i've been driving in a spirited manner, even when at trackdays. I simply don't have the time or courage to take my eyes off the road for that long while 'on it'.
A water temp and an oil temp would do me perfectly for the center console. I can look at these -after- doing afew laps around a track and they dont move radically enough (like a boost gauge) so I can look at them when I -want- to not when I -need- to.
What are some good brand gauges? Where can these be bought from at a decent price and what are some websites with pics/specs/prices/etc ?
benm, often guages are more important for tuning than actually racing. all my defi guages have warnings so if any of the guages go over or under a certain limit it a really anoying buzzer sound and the wonderful red light shows up. i purchased all defi bf series guages. got two more to get. only problem i have found is i need three controler boxes to be able to connect all the guages i have. (two so far need one more for the last guage).
probally the cheapest guages i know of would be vdo, but if you go that way get the kenworth version (has to be purchaced from kenworth themself) from memory you can get the guage and sensor for about 70$. they dont have any warning or recall option. the advantage over the vdo guages (unless vdo has changed recently) is at night the numbers light up thought the backing insted of light simply being let pass from arround the edge to try light the frount panel inside, which isnt that effective.
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
