anyone know what the hose running from the intake pipe closest to the jay pipe to the back of the power steering pump is for ? some days i seem to have vairing degrees of feel to the steering . appears to get heavier when driving spiritedly and quite light when just cruising . any thoughts ?
99 RS four S
Edited by lachlanw
https://www.sau.com.au/forums/topic/228725-vairable-power-steering-assistance/
consider a power steer fluid cooler, sounds like the fluid is heating up, changing its viscosity, creating the heavy steering feel. Most of the Skylines are fitted with a small tube one, our cars were not designed be thrown around as much. Not sure what the hose is, also consider changing the fluid, i use transmax Z in my PS, found it gives a lighter feel and handles the higher temps better. Ive been planning a PS cooler for a while now, ill get round to it soon.
there may be easier and less messy ways, but the way I do it is, 2 hoses on bottom of resovoir, one is fluid return, other is fluid out. Place towel under resovoir, unhook return hose, (dont ask me which one is which ?) need to plug up hose connector on bottom resovoir immediately to stop it draining, use same diameter piece of hose with tight bolt in other end. I then extend this return hose with another piece of hose and a hose connector so you can feed it into a waste container. get new fluid ready, have mate turn on engine and make sure resovoir starts draining, if not then you prob have wrong hose, once nearly empty start filling resovoir, keeping a good fluid level, have mate turn wheel side to side a few times. Once drained fluid colour changes to new fluid, stop, reconnect, check level. Go for drive, check level again.
had my cover off today and there is a line running from the afore mentioned intake pipe to what looks like something similar to an oil pressure sender unit its on the line coming out of the power steer pump. has another line coming off it that is dissapears down by the block . and by heavier steering i mean it has more feel and need to hold on tighter . by no means is it heavy heavy
Edited by lachlanw
On series 2 neo (not sure about s1) there is 2 pipes connected to the power steer pump.
One line connects the the intercooler pipe which runs between the intercooler and the throtle body.
There is a second line which runs behind the timing belt cover and connects to the inlet plenum near the fuel reg
I had mine disconnected for a while when I fitted the fmic as the kits do not come with the extra nipple in the intercooler line
To be honest I did not fell much difference, but I did only drive it for a few hundred k's like this. I then fitted a new nipple to the intercooler pipe and hooked it up again.
It most be reading boost pressure, so when pushing the car, ie on boost, there must be a change to the power steer feel by operating a pressure relief solinoid on the back of the pump. That is my guess.
The one I've been driving is noticeably heavier on the highway/at higher speeds than it is around town, in fact its very light at low speed. This is consistent too. Surely it must have some sort of variable assist?
yerah i agree with you guys aye . sometimes if you are taking off during a 3 piont turn ie taking off while on full lock and give it a bit of boost it has real heavy steering but goes away straight meh . i like it how it is tho . seems to be set up at a farily good ratio for how i like my steering . two hands when you boostin it and light as when cruising on thw high way
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
