Hey all. Does anyone know with the new laws what is going on with p-platers and the demerits?
I was told (by a police officer) that if you lose your license on you p-plates you have to start all the way back at the start, as in do everything again, even your log book. Is this right? As Ive been also told that all you have to do is the theory test and hazard test again.
So whats the deal? Also something about a gradual demerit system?
https://www.sau.com.au/forums/topic/228761-p-plate-laws-and-recent-crash/
  • Replies 209
Yep, if your one ur p plates, and u use all ur points.. you have to start again from the start... they pretty much cancel it.
If your not on ur P plates, it simply gets suspended... meaning once you reach the date, you can jump back in your car and start driving again without having to do anything.
It's always been the case that if you get a suspension while on your P's your license gets cancelled. I am from the pre-logbook era and I lost my license the first time, 3 weeks before I was sposed to come off my P's. Had to resit my L's and practical driving tests.
So say you got done doing say for example 100 in a 60 zone, but they didn't actually get the speed due to the fact there was no radar. So would it just go to court I guess and then what would happen? If found guilty? found not guilty? What would you think the decision would be and the punishment if any?
It wasnt me that go caught speeding, someone i know. When asked what evidence there was she said that it would be her visual observation and her notes that she took down. Then he got the summons in the mail saying he was doing 100kph in a 60 going onto 70 zone.
a month or so ago I got done doing in excess of 140 in a 100 zone. me and 6 others actually, all at the same time. and same case as yours. estimated according to the cops speedo and no radar gun.
I called a few of my cop friends to see if what they did was legal. Apparantly they are allowed to. the patrol car speedo does get calibrated every so often (how often..who knows). Both my cop friends said there it's very possible of winning the court battle in these cases, but never guaranteed.. unless of course there was only one police officer in the car and present there..then its 99%. It was my first infringement with nearly 2 years of driving so we all paid the fine ($700 and 5 demerits). 2 of my friends lost their license from it. One was a p plater so I could ask him the next time i see him about what's going on with his.
The reason I paid mine as I said it was my first fine ever and court+lawyer fees would equate to around $700. If you want to take it to court you have to write a letter requesting the matter be disputed in court. (this is for the fine). If not you will have 28 days to pay the fine and thats also the timeframe to send that letter in. I'd dispute it in court if I was losing my license over it.
Sean do you mean if you lose more than 4 points.. or have 4 points remaining? LOSING 4 in total is very harsh.. and isn't good for me.. :)
Edited by Magic
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
