Hey guys,
my boyfriend is Adrian (s13_boi) he owns a white supra with NOS (u may have seen him on car cruises)
We are both entering autosalon (my r34 and his supra).
He took his car to the painters on Saturday to get his awesome new kit sprayed for Autosalon (this weekend).
His painter rang him this morning and said his car had been broken into!!!
Adrian quickly rushed down there to see what happened..........
They:
- f***ed the door key hole
- stole his deck
- stole his moster tacho
- stole his 2 amps
- stole his sub
and even stole his NOS bottle!!!!!!!!!
oh and the even tried to steal the lines to the NOS bottle!!
his car alarm went off, but they ripped out the speaker........
Adrian is absolutely devistated.
I know my fellow skyliners are good good people, and was wondering if anyone can help him out with anything? (not to keep just to borrow even)
just for autosalon so he can have his car in.
It should make him feel a lil bit better about the ordeal......
Adrian is an awesome guy and is always willing to help (and does help) everyone he can!
So im asking you........... can you please help him just for this weekend?
Cheers... Erin
aka: Anahera
https://www.sau.com.au/forums/topic/228977-people-are/
hey vinnie, adrian here.
dont worry bro ill get u a new bottle they also on the bottle was the nos pressure guage and ryans bottle warmer so ill be gettin that all back with insurance, im really sorry man
the workshop should be covering all damages and missing items, that also broke into the 180 which was parked next to me, it was the owners car, and pretty much took any thing they could.
fkers even took my cd's i was wondering why my glove box looked more empty than usual.
thank you all for your support
https://www.sau.com.au/forums/topic/228977-people-are/#findComment-4028071
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
