Hi Everyone,
Just need a little technical support, my GTR is running the standard airbox with a K&N filter. My mechanic is telling me to go for some pods and get rid of the factory airbox.
My car already has an HKS drag intercooler and 3.5 inch exhaust from the turbo. I have been told that the only thing letting the car down is its breathing ability and that I should expect a noticable difference.
Any advice would be greatly appreciated
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/
If u do make sure you build some type of cold air intake (see: forced induction area), otherwise you're just going to be sucking in warm air which may give you worse performance.
Some argue pods are a waste of time compared to a good panel filter, but they sound better :(
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491283
Originally posted by Canadian GTR
Leewah
Did any of those GTR's have any mods to their standard airbox,
extra cold air feeds running into their standard box or airflow meters??
No. Because of the way the airbox feeds from the front of the bonnet anyway, it was cold air already feeding to the turbos.
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491337
Leewah,
I guess what I'm trying to find out is if the standard box provides enough air to the turbos given the mods I have, or would an additional air supply be benificial, say for example if I added another cold air feed from the front bar into the standard box.
Or would that be over kill ??
Cheers
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491402
There is no real such thing as overkill when it comes to feeding the turbo cold air. What you need to try to accomplish is giving the turbo as much air as possible as long as the air is cold and directed in a straight line. Turbulant airflow has a very negative effect on the effectivness on a turbo. We found a 4 rwkw loss by simply removing the air pod. We found that the air pod directed airflow in a less turbulant direction so we left it on.
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491453
hehe all i can say is if u slap on that pod go get an engeneers certificate for it or when u get pulled over the nice little men in blue will be putting a nice little yellow sticker on your windscreen, and acting as if there mechanics when there telling you to put back your origanal air filter lol :) good luck mate you got to weigh up the for and against mate but id put one on anyway :D
and if your going to do it do it proply with the right filter dont get some REPCO $5 filter just to save money get quality stuff its enhances the performances and last longer as they say you get what you pay for
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491772
I think I will leave the box standard and try to feed it more air through the front bar.
If anyone had done/tried this on a GTR I would love to know !
Thanks for the help
I know a couple people both in GTRs who run a standard airbox and his best time so far is 11.4@124MPH
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491942
Thanks everyone,
Thats the great thing about these forums you can chat with people who have been there and done it rather then taking the advise of a mechanic who wants to make more money !!
I'm going to stick with the standard box and get my hands on some cam gears next !!
I will probably need some more help when I get closer to buying them.
Cheers
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-492974
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
