  • Replies 665
Posted Images
YALL GON MAK ME LOOSE MY MIND, UP IN HER, UP IN HER
anyways Adrian put down a seperate order for me for:
Hoodie
Black
no username
Medium
$50 fitty dowlah.
Edited by Damo_R34
Sorry Ruby, this is for Adrians benefit:
Good work Adrian AND DAMO :thumbsup:
hoodie/jacket: JACKET
username/real name: RUBY
name in caps or not: CAPS
colour: BLACK
how many: 1
Will make the transfer tomorrow, clear by Thursday
Extra: might as well get one for the missus
username/real name: RUBY's GIRL
colour: BLACK
how many: 1
hoodie/jacket: Hoodie
name: Cronic... (including the dots)
name in caps or not: no caps
colour: black
how many: 1
colour: Black
how many: 1
Transferring the $$ now, will PM you
hoodie/jacket: HOODIE
username/real name: GRAHAM_R32
colour: BLACK
how many: 1
=$56
username/real name: R32_SKYLINE
colour: ROYAL
how many: 1
=56.60
plus $10 for postage
Total of $122.60
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
