  • Replies 665
Posted Images
ok guys a real update now. Going with all Gildan hoodies and zip ups, so a few things have to be clarified.
Pete and Kellie - please advise me of which of these sizes will suit your respective children (they are childresn S, M, L and XL):
Measurement (centimeters)
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Responses ASAP please guys.
Thanks
Damo, as per phone conversation, I'm guessing the young fella will be a Medium......I'm hoping that's the equivalent to a size 10.
Those above sizes are weird.....I'm assuming that 43.52cm is the measurement across the chest or back, not around the chest (based on that length).
So go for a Medium unless you find out something different about the new sizing.
hey lauren just freaked out a little haha
she was pissed before ther was no pink in colour choice, so now shes happy....
but yeah can u make it light pink please :P
ta
ok so pink for Lauren, Pink For Vu (or Mel :P), medium for Daniel, Small for Locky, so just waiting on lin33r.
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Lin33r, Vu and Kye, light blue is not available in the gildan range, so would you like to change to royal blue? Or you can choose another colour, found below:
light pink, white, navy, black, red, royal, and sport grey (light grey). the colour chart is here, please look under the "FLEECE - 18600 range" http://superioraw.com.au/images/colourguid...urguide2008.jpg
Thanks
CRAP! is it just me or are these szes TOTALLY different???? i'd probably be an XXL or XXXL in the new brand of tops, are we able to change that???
18600 S
51cm x 69cm M
56cm x 71cm L
61cm x 74cm XL
66cm x 76cm 2XL
71cm x 79cm 3XL
76cm x 81cm
All WxL and slightly different to the sizes you listed earlier for gildan...
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
