  • Replies 665
Posted Images
ok guys a real update now. Going with all Gildan hoodies and zip ups, so a few things have to be clarified.
Pete and Kellie - please advise me of which of these sizes will suit your respective children (they are childresn S, M, L and XL):
Measurement (centimeters)
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Responses ASAP please guys.
Thanks
Damo, as per phone conversation, I'm guessing the young fella will be a Medium......I'm hoping that's the equivalent to a size 10.
Those above sizes are weird.....I'm assuming that 43.52cm is the measurement across the chest or back, not around the chest (based on that length).
So go for a Medium unless you find out something different about the new sizing.
hey lauren just freaked out a little haha
she was pissed before ther was no pink in colour choice, so now shes happy....
but yeah can u make it light pink please :P
ta
ok so pink for Lauren, Pink For Vu (or Mel :P), medium for Daniel, Small for Locky, so just waiting on lin33r.
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Lin33r, Vu and Kye, light blue is not available in the gildan range, so would you like to change to royal blue? Or you can choose another colour, found below:
light pink, white, navy, black, red, royal, and sport grey (light grey). the colour chart is here, please look under the "FLEECE - 18600 range" http://superioraw.com.au/images/colourguid...urguide2008.jpg
Thanks
CRAP! is it just me or are these szes TOTALLY different???? i'd probably be an XXL or XXXL in the new brand of tops, are we able to change that???
18600 S
51cm x 69cm M
56cm x 71cm L
61cm x 74cm XL
66cm x 76cm 2XL
71cm x 79cm 3XL
76cm x 81cm
All WxL and slightly different to the sizes you listed earlier for gildan...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
