  • Replies 665
Posted Images
just incase anyone doesn't know about Charmaine's car, here it is:
THE LASER:
I absolutely love my car. It’s a 1991 Ford Laser Ghia. I bought it with 17” chrome rims and it was lowered. I was like “Sick! A pimped car!” But after closer inspection I discovered the car was lowered illegally as the springs were cut. So not too long ago, with help of a good mate, we put in new lowered springs, suspension & rear brake pads. Still need to replace the front pads. The car was all good and well now but I couldn’t drive around without some sick cranking tunes. So the next step was to upgrade the soundsystem. This I can also thank my good mate for, as he was an absolute gun for helping me install all of it. A few hundred dollars later ;) my soundsystem consists of a Pioneer sub, Kenwood 6” splits, Pioneer 6x9”s, Boss 4 channel amp & Boss mono block amp and a sexy Alpine headunit. Doof doof much?? The interior and engine could do with a bit of work I suppose, but hey, it’s only my first car and it gets me to where I need to go. I’m not sure spending copious amounts of money on my first car would be the best idea because eventually I will have something better. Either that or the fad will end. But somehow I don’t think it will. I’m keen at the moment for a new exhaust, cannon + extractors. I love driving. I feel happy when i drive, the feeling of just being able to get away from everything. Like an escape. Especially with the music cranked loud XD
Yeah. My car is the sex.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
