Contact: Sam
Number: 0417 958 454
**Pickup Only**
ALL ENQUIRIES, PLEASE PHONE ME, I AM NOT CONTACTABLE ON THESE FORUMS
Item: Apexi Power FC
Price: $1000
Condition: Used for 5000km approx. Tuned for S2 R33, full exhaust, FMIC, Bosch 044 fuel pump, std injectors with adjustable fuel pressure reg, High flow turbo running 18psi - 220kw, standard motor.
Item: Z32 AFM with plug
Price: $220
Item: R33 5spd gearbox with almost worn 5 puck ceramic exceedy clutch, and tail shaft(R33)
Price: $1500 ono
Condition: Done 108,000km, excellent condition
Item: R33 S2 motor, Does NOT come with turbo, fuel rail, injectors or coil packs. Does include head (perfect condition) with adjustable exhaust cam gear. Includes flywheel.
Price: $350 ono
Condition: Block has slight damage near water pump(as seen in pics), sump is bent, otherwise in excelent condition.
Item: R33 s2 diff
Price: $300
Condition: excelent
Item: R33 brakes (calipers, rotors, entire assembly) front+rear
Price: $500
Condition: excelent
Item: White R33 rear boot lid with drift style rear spoiler including hinges and struts
Price: $350
Condition: Perfect condition
Item: White original R33 S2 rear wing
Price: $50
Condition: excellent
Item: R33 tail lights
Price: $100 each
Condition: perfect, working condition
Item: R33 GT-R rear sway bar
Price: $50
Condition: excellent condition
Item: R33 S2 interior (front seats, rear seats, rear trims, scuff plates)
Price: $350
Condition: perfect, no marks, no holes, as new
Item: R33 floor mats
Price: $100
Item: R33 split dump and front pipe (1pce) - stainless
Price: $130
Condition: Slight damage on wastegate pipe - can be repaired
Item: Drivers door - white (not including mirror). Includes glass, hinges electric window motor etc.
Price: $250
Condition: very small damage to door trim. Paintwork very good condition.
Item: Passenger door - white (not including mirror) otherwise complete
Price: $300
Condition: Excellent to perfect condition
Item: mirrors
Price: $100 each
Condition: Excellent condition
Item: Rear insert (goes between lights / under bootlid - reads skyline), white S2
Price: $50
Item: White R33 fuel cap
Price: $50
Item: Electric antenna
Price: $50
Item: R33 white rear bar (custom modified to make number plate area neater for aus plates)
Price: $200
Condition: Very good
Item: Inlet pipe with factory blow off valve fitted
Price: $50
Item: Automer guage (boost with cup and mounting bracket)
Price: $50 ono
Item: Automer guage (oil pressure)
Price: $30 ono
Condition: new in box
Item: drift Catch can
Price: $20
Condition: scratched, but perfect working order
Item: Blitz pod filter
Price: $150
Condition: very good condition
more pics to follow
Edited by gucc_33
https://www.sau.com.au/forums/topic/229077-wrecking-r33-gtst/
ill do tail lights for 150 and i am willing to split up the brakes and power fc comes with hand controler. please call do not have the net and have to rely on a friend so is hard for me to be on line. cheers
I got a S2 rear wing off this guy today. He is a very genuine and friendly bloke. I went and picked it up today from Moorabbin. As mentioned above, for a fast reply please sms or call him for info on the stuff . I don't think he is on this site to often.
Thanks again Sam and all the best selling the rest of the parts.
Also for sale:
Item Adjustable exhaust Cam gear
Price $50
Condition Excellent, like new
Please note, I can't always get on the net, I need to use my neighbours computer to post, please call the number in the first post if you are serious about buying something.
Cheers,
Sam
  • 8 months later...
  • 3 weeks later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
