looking for cold air box for pod filter prefer carbon fibre
places that sell them?
located in melb
thanx
Top Stage in Melbourne Sth East
www.topstage.com
carbon fibre , im ordering one from him as well
cheers,
David
they are located in Clayton... thats all the info i got so far
did you guys find out what materials and prices they have?
i'm waiting on a reply from Freddy now
ordered one from these guys a couple of weeks ago for my R34 GT-T. the guy is pretty slack so don't expect a reply to email for at least a week. Was $240 plus delivery which was about $16 i think, but these boxes are top quality. definetly worth the wait :starwars:
That looks nice, i definatley need to get one of these installed.
Do you think you will have issues with police if they look under your hood with this box sealed like this ? i.e FMIC & Pod Filter legalities
Wouldn't have a clue mate. Think we have different laws here in SA to Vic.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
