ey guys just need a couple of bits of info. Need to know are the r33 series 2
positive or negative door triggers
where is the central locking module is it under the dash tucked away and hard to get to like the box i saw 2day
wat plug is it how many pins
and what colour are the two lock and unlock wires i need to hook it up 2 my alarm.
Last bit of info i need to get to get this alarm all working properly.
Also any ideas on sum imobiliser points?
and which wire is the engine starter wire as i am hooking up a remote start
also i need a negative tacho wire, any1 know where abouts i can find this?
cheers all
adam
https://www.sau.com.au/forums/topic/229430-alarm-issues/
not trying to steal one are we :P
i think it best you take it to a trusted alarm fitter because im recommending if anyone does know not to tell you
these boards are a wealth of free information about our cars. HOWEVER that sort of information in the wrong hands is what see's them go missing
now i may have over generalised here but
1) we don't know you YET
2) you haven't been with the community very long either
3) so many skylines get stolen each year if your are 110% above reproach then you will forgive us for being cautious
for alarm fitters i recommend Ric at Auto Perfection or John at Marvey Tech, Ric does SAU discount on alarm installs and tinting so mention skylines australia and he will know you've spoken to me
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4033095
ok thanks for thinking im dodgy but oh well
got my new alarm in, eveyrhting works as afar as central lockin, immobiliser, etc etc
my only problem is that i cant get the remote start to work, i have relay hooked up to the ignition barrel but i dont know if its hooked up properly, any1 have any ideas?
Thanks Adam
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4034327
Thanks Adam
by the way have a relay with 5 different wires they are
blue red, blue, blue white, thin red and a thin black, need to know is the start on the ignition the same as the starter module, does that wire run tot he same position? CAues says to hook the blue to starter module, blue white to start on ignition and red goes back to alarm as well as black kinda linkign through, ill scan the diagram 2morrow and post it to show u wat i mean but if any1 has any idea son this much appreciated.
Cheers Adam
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4035425
Thanks Adam
Get remote start installed professionally, unless you want to risk this: http://www.redflagdeals.com/forums/showthread.php?t=476556
And remember, never leave the car in gear when off. :D
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4036914
And remember, never leave the car in gear when off. :)
yea nah dude i wotn have this problem, i got my self a xxxxxxxxxx 2way pager alarm which has many features include voltage sensing and tacho sensing along with handbrake sensors, so if the car does try and start and the voltage either drops, the revs go all retared wen started in gear or the hand brake is down the car will die instantly/wont start at all, so it should all be fine. THanks for the heads up anyway i thought of all thsi ebfore doing it anyway
edited by Nightcrawler: mate don't tell potential thieves exactly what brand and model alarm you have - that is just dumb
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4037512
^^^^ how dumb is that guy to 1) leave his car in gear when he has a remote start system, and 2) make sure the installer installed the neutral sensor property. That should not be physically possible to happen. And how did the car start in gear with the handbrake fully on. Sounds sus to me. Just for fun those guys with manuals try to start your car with the handbrake on and in gear - I guarantee that you won't get very far. Feel free to correct me if I am wrong.
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4037531
Yea, if the handbrake was on, the car would just bunny hop - instantly stall and shut down...
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4037755
anyway thanks guys for the help, not, foudn the wires i need i think. Tried 2 hok up the rmeote start but with no luck yet, dunno wat i could be doin wrong. Oh well ill figure it out one day. At least everythin else is workin. Cheers anyway
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4042097
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
