Item: Trust Td06 19c turbo kit.
Condition: good
Price: $1200 ono
To Fit: (What car) skyline (any car with RB20/25)
Contact: Jayson - 0409 869 892 - [email protected]
Comments:
Happy to ship at buyers expense
Turbo
Dump pipe
oil line
All hoses pipes and brackets to bolt up to an rb20/25
Turbo is T3 flange so will bolt to any standard manifold.
Made 275rwkw on 16 psi.
Turbo kit is in good condition, only selling because I bought a GT30
https://www.sau.com.au/forums/topic/229507-td06-kit-suit-rb2025/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
