The thought has crossed my mind to sell my 33 GTS-t as i am wanting to buy something faster... Thinking of a GSR Lancer 4WD with all the EVO running gear etc.. in it.. Runs a mid - low 12...
But i have been doin some thinkin and may be should perhaps keep my 33 and put in the difference in buying the GSR... approx $7k....
Do you think this budget should see me around the same et's as GSR?? Considering all i will need to do is turbo, management, fuel system, i can get parts made/fabricated etc.. Got cooler, exhaust etc..
What do you all think, i am sure there are more other people out there in the same sort of predicament as i am?? Let me know your thoughts.. :):P:(
https://www.sau.com.au/forums/topic/22969-thoughts-on-selling-my-line/
Sil8ty...good topic,
I guess it depends on your current situation. How much faster are you willing to go for the dollars. How much power does your current ride hold atm? Assuming you have basic mods already, some sort of air filter kit, cat back exhaust, boost controller, stock ecu and possibly a front mount i'm guessing your round the 160-170kw mark at the wheels? For around the budget you mentioned you could compliment what you have with a newer ecu, bigger fuel pump plus a fuel pressure regulator and larger injectors. Which would certainly give you that kick in the pants u R looking for. GTST's r becoming a lot more common (admittedly) but thats only because they R a Kick-Arse car - They still look the goods. But if you've got your heart set on a change of wheels the GSR is only a suitable replacement in terms of performance but not looks IMHO. I'm not too familiar with the Lancer but the 4G63 engine is supposed to be an absolute demon with mods. Or you could do the next best thing... as Jase said and get a 32 GTR!
Jase: This is my eventual goal, to one day own a 33/32 GTR .... :P
GT-Rmgedon: Well here is a quick run down on what i got/done to date to me 33.. FMIC, Modified Inlet Manifold (t-Body to front), Turbo back exhaust, Pod filter, H/Duty clutch... Next steps would be to do ECU (PFC or likes), Turbo, Fuel sysytem... Bottom line is it is not FAST ENOUGH :burnout: ....
You must admit though the 33 has a awesome shape/look and will be hard to beat in this area.. The GSR on the other hand with a bit of a kit (EVO III Style) does have a reasonable look.. But does seem to provide better bang for buck performance wise, with the common 2.0L engine swap, cooler, turbo, management gets them a 12 sec slip with little effort.. opposed to the larger 33.
I am still undecided.. I love my 33, but i have, i guess youd call it a need for speed.... :) (and more money to spend on a damn car)
Thanks for replying to guys.. Its appreciated..
RWD's are fun, yet extremely frustrating not being able to put the power to the ground.
imho, a GTSt isn't a true sports car, i believe its far too heavy. if you like power & handling maybe an S14 could be an option? they are easy to get power out of. another alternative is the Silvia or 180SX with an SR20...
GSR's are a great car. they are light, they are powerful & they are 4wd. deadly, but boring, package...
I have been thinking about this whole scenario.. I know the good old 'line is the schweetest looking car around to date.. With in reason.. ;) And i will probably regret it, but i will still have the ambition of wanting the GTR (even if i have to wait til the 34 is 30 years old with 300,000km's on the clock, selling for $1,000) I wish.
I spoke to a few people today, and i reakon i will also consider the S-14 as an option also... Seems to have the same comforts inside, and has got good a healthy weight as well as the good old SR under the hood.. And it is still RWD :burnout: :) I know alot of you know what io mean... And they are good value too now..
Thanks for your input guys.. Will let you know what i end up doing though.. Either way i wont be leavin the skylinesaustralia forums..... :D
IMO there's not much to upgrade to.
It's either an r33 GT-R or an r34 GT-t sedan.
I do like 4 door sedans to be quite honest but I only like cars like the BMW M5 or 535i or Commodore SS or Falcon XR6T. But they all have their problems. The r34 GT-t satisfies my four door lust. In some ways I like the Stagea too.
I find all non attessa 4wd systems to be just inferior. What can one say about the GT-R???
I think the Silvia is not an upgrade to the Skyline GTS. I find the cabin less impressive, the chassis less impressive, uses the same fuel, same sorta power, mods are slightly cheap... IMO more of the same problems as the Skyline but lesser.
I am fussy about cars and ATM the GTS is it. If you can name something better that's not a GT-R I'd like to hear it.
T.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
