Item: Rays Gramlights 57 PRO 18 X 9" +12
Condition: Excellent, There are couple of minor marks on the lip from dropping wheel nuts on it (check photo below – not even noticeable) No gutter rash at all.
Price: $3400 ono ($2600 without tyres)
To Fit: (What car) GTR – R32, 33 and 34
Contact: 0433575740
Comments: Tyres are Nankang ultra sport NS II 265/35/18 near new. They were fitted on my R32 GTR. These wheels cost $825 each when new without tyres.
  • 3 weeks later...
hello,
im interested are they still available? I was wondering if you were using spacers on the r32 ... also why are u selling them? also do u know the counterbore size?
thanks,
justin
PM sent
hello,
thanks,
justin
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
