Just a general question... where does one go to get a good quality v-band clamp and not one that looks like it's going to bend / snap when tightened up?
I don't mind spending a bit of money so even if it's completely overkill, throw it at me.
I recall someone on this forum once posting up a photo of a billet clamp of sorts (made for aircraft I think), was purple.
Thanks in advance
S
https://www.sau.com.au/forums/topic/230020-v-band-clamps/
Thanks for the response...
Yeah they're the ones that were posted before, but now I see them again - they're not what i want. I am in need of some quality V-Band clamps. Do they make something similar but in V-Band format?
Might get a few of those Wiggins ones for elsewhere!
Thanks bud
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4042058
Wouldn't have thought a wiggins clamp would pull down hard enough to be used on a radiator hose. They use flanged pipes and orings, they don't use compression to seal they use the orings hence their flexibility?
I'm sure if they can hold intercooler pipes they can hold a radiator hose
cooling systems only get to ~1 bar
Yeah great - got quoted about $500 for a 4" Wiggins clamp kit today... that's ONE CLAMP... does anyone have the number for an oil tycoon in Dubai? My best friend just got fired...
told you they were dear as poison LOL
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4044814
Adel Wiggins Flexible Tube Connectors, known familiarly as Wiggins Clamps, provide an ideal method for connecting and sealing two tubes.
They are available in aluminum with a stainless two-finger latch, and are frequently used for vacuum lines, water lines, and turbo intake plumbing.
All are qualified to AS1650 and MIL-C-22263 specs., and are tested to greater than 125 psi. operating pressure, at temperatures up to 450° F depending mainly on the o-ring material.
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046021
Ok deleted the last post and will try again. You can't just buy a wiggins clamp and slam it on over your silicon joins/hoses, there not that type of clamp. They can only be used for metal piping as you need to weld on the ferrules. Yes I know you can use them for pretty much anything. Had a quick look around for some pics to explain what I mean.
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046190
same goes for V band clamps. they are only good to join to pieces of alloy or steel pipe since you need to weld the appropriate flanges to the 2 pipes so you can use the V band clamp on it.
V band kit:
another good example of V band clamps and flanges. they are good for IC piping, and exhaust if you have the time and money to install them. :)
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046217
can these be used on radiator hoses and such??
wiggins clamps can
but they are dear as poison
Just sounds to me like your saying they can be used on silicone radiator hoses....
https://www.sau.com.au/forums/topic/230020-v-band-clamps/#findComment-4046218
  • 5 weeks later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
