any engine will knock, whether it is PFC or stock ECU........ i would worry too much about it, a friend's R34 did that as well and he never mention anything about being worried about it, but if in doubt get it checked out by your mechanic/dyno dude :rolleyes:
any engine will knock, whether it is PFC or stock ECU........ i would worry too much about it, a friend's R34 did that as well and he never mention anything about being worried about it, but if in doubt get it checked out by your mechanic/dyno dude :)
lol no, only a PFC will trigger the CEL for engine knock, the stock ECU will not display the CEL if there is any knock detected....would be great if it did :rolleyes:
If it was a brief flash 9/10 it's the O2 sensor, if it goes on an remains on, most likely coil packs..run the diagnostic to be sure.
Paper clips at the ready!!!!!
As the document says, turns the ignition to "on" short the two terminals indicated on the consult plug (clipped covertly on the underside of the dash near where your right knee lives), count the flashes, look up the code
diagnostic.doc
Thanks Dan lol
  • 4 weeks later...
Hi all just to clarify... This happened to me today. The engine light turned on and stayed on after 10 minutes of driving. I didn't feel any change in the engine etc. car felt as usual no hesitation, shakes or missfires.
I pulled over waited a few seconds and restarted - engine light was off and never came back on.
I guess i'll have to drive the car more and observe if the issue comes back.
My car is an r34 non-turbo auto btw.
What is the consensus on this? Bung sensor or coilpacks about to give out or ecu glitch (if that even happens)???
Definately coil packs, fitted Splitfires and iridium plugs to mine today. My engine light had been on for a week and a half but like yours had not yet shown any signs of hesitation or missfiring yet. Just ran the engine, no engine light on and appears to be running much smoother and cleaner than before.
Splitfire coilpacks, part# SF-DIS-008, Brought them from CRD in NSW for $510 delivered, awsome service as they arrived a day and a half after payment.
NGK Iridium spark plugs BKR5EIX-11 $90
Also have NA R34 Good luck, Nath.
this happened to me, engine light came on and it dropped a cylinder, car would shake quite a bit, so i unplugged the coilpack plug, replug back in and the shaking went away.
pin pointed it down to the one SOB coilpack so i replaced that.
hopefully its fixed now as i only did it 2 days ago but so far so good, the light would come on intermittently, sometimes it would last a week without issues or maybe a day... but then in future if more packs let go, its time for splitfires.
My engine light came and and I got a service they hooked up the Nissan computer but they couldn't find the problem. I rang Power Road car sales where i bought my R34 Gt from and they identified the problem by just me explaining it over the phone.
I just got a new coil pack installed by them today, costing 240, (130 for the coil pack form Nissan) They also claim to have a machine that tells them which coil pack is playing up.The car runs smooth now, but my engine light is still on. I was told that the computer needs resetting, but I would have thought that the light would switch its self off once the problem is solved.
Does any one know how to reset computer or do i need to take the car to a specialist?
^ dc the battery, step on brake a few times to compeltely drain the power.. wait a few mins, connect battery back up & thats it.
but after u change the coilpack, u turn it off and then turn it back on and the engine light should go away.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
