Hi, all selling complete r33 skyline gtst s1.5 95 model
used
black
auto
71,271km
compression test 3 months ago at spec r in dandy
173, 169, 175, 172, 175, 172 PSI
Complete car 4,000 Am taking Negotiable offers
Inspection Welcome
Contact : 0401275368
EBAY LINK : With Pics
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E:IT&ih=012
Not seperating parts unless
Purchasing Engine Complete Package $1,800 Included wateva Needed In Engine Bay
Gearbox+diff+tailshaft n other pits need $450
Thankz all like to hear from uz Soon
Theo
https://www.sau.com.au/forums/topic/230183-r33-gtst-s15-1995-model-auto-black/
Bump is it to expensive please tell me as i dont think will accept negotiable offers
no damage to rest of the car besides front right rail and radiator support bar
no damage 2 running gear or engine etc.. perfect nik
Well you got quoted 1500 to fix radiator support and front reo...
Then someone has to buy all the other parts,
bonnet - 200
Guards - 150 each
front bumper - 250
reinforcment bar - 150 (if they dont supply it in the quote)
radial support frame - 100 (if they dont supply it again)
guard linners - 50
headlights - new 1200 - second hand 400
Grill - 80
Of course some parts could be bought cheaper, though some more expensive.
now that is just shy of $3000, Without paint.
So $7000 (without paint), when some auto series ones are going for $7500.
At that price only a panel beater or someone stripping it will benefit in my opinion
Ontop of all this the buyer has the headfcuk of finding all the parts, organising and waiting for the car to be fixed.
I hope you get what your asking for it but as said, it will most likely be a panel beater/painter.
Edited by bluey33
Then you should advertise that on your ad for sale, as I said most parts could be bought cheaper.
If you add that you are guaranteed to have more interest.
thanks for your reply bud
yeh as i said importer works in relation witth vu from dt panels
2.1k for all parts
1.5k fix for da right rail n radiator support
total 3.6k
rest just respray if some 1 wants 2 keep it black cheap respray on the front mix n match will do fine or if they want diffrent colour its down there ally i guess thanks dude for ur reply
TYPOOO
i will accept negotiable offers LOOK STRAIGHT OUT 3,600 CAR GONE CANT GO ANY CHEAPER 3.6K TAKE IT RIGHT NOW ASAP
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
