  • Replies 66
Posted Images
ok i need to do more reading and possibly Pete or Helso if i could get samples of your O2 sensors i can go into Petro-Ject and see what we come up with
According to Duncan, in the O2 sensor thread, the NGK part number is OTD2F-P1P
yeah thats the titania R32 GTR one maybe R34 use titania also i dont know maybe you can pm me your VIN and i can ring nissan or you can ring nissan with your vin and get a part number
Hi there, I need 2 each (I think) for R33 based Stagea 260RS. Just to muddy the waters (maybe) I have copied this little lot, old prices from around 2005, from the o2 sensor sticky;
OXYGEN SENSOR replace @ 40000kms (ref sydneykid)
NGK/ NTK Part number OZA395-E2 O2 Sensor Nissan Pulsar N14/N1
Genuine article no need to change plug or anything.
NGK OZA395-E2 (This comes now as BOSCH part number 2269013007) $129 from REPCO
Genuine Nissan
Part number - 22690-83T12
$169.00 each
What is the expected delivery date considering your closing date/order quantities are met? Does the price include GST?
Cheers GW
Hmmm interesting mate. That is a Zirconia sensor, so maybe I am in luck. As I posted in the other topic, I managed to get some part numbers off the sensor. It is a Bosch with A24-A21 141 xxxxxx. I couldn't work out the xxxx part, but I did a Google search which showed someone selling one second hand with the part number A24-A21 141 63072. I also found another forum where they said it was Zirconia, so who knows? I'll see what I can find out tomorrow.
well i imagine then if OZA395-E2 is for the RS260 then that will also suit the R33 GTR since you share the same engine who ever though O2 sensors could be so hard
Mine is a 260RS anyway :blink:
Genuine Nissan
$169.00 each
Cheers GW
Hi there,the info part #'s I posted related to RB25DET I suspect as SK has auto Stagea. At the end of the day it is all gunna relate to your ecu & what model Skylines/Stags use similar ecu's. The discussion regarding Titania(ium?) oxide vs Zirconia oxide I imagine relates to different response curves of the two primary elements when exposed to oxygen, which means the compatible ecu's will have different input measuring ccts. Maybe we take a punt & say R33GTR o2 sensor will suit 260RS & R33GTST will suit the RB25DET equiped beasts? R32/R34 series cars............dunno. Just found this...........Check out the attachment. Narrow & fast (Titania) vs wide & slow (zirconia)?
Anyway I am happy to buy 2 x (NGK/ NTK Part number OZA395-E2 O2 Sensor Nissan Pulsar N14/N1
Genuine article no need to change plug or anything.) for my application, I will sell the buggers on ebay or something if they are the wrong jobbies & try again.
Cheers GW
All_About_Lambda_Sensors.doc
im trying to get O2 sensor's sorted for all models R32 RB20 but no one has asked for them so havnt had to look for any info R32 GTR to which i thought would suit all RB26 models so this is all new to me when i started the group buy based on the NGK website only having 2 part numbers 1 for R32 RB26dett and 1 for R33 RB25det i may the ASSumption there was only do 2 sorts for the 3 variety of engine model cars, if that makes sense
Sorry mate im confused, I need 2 x R33 GTR O2 sensors.. can you get those in?
yeah cheers for all your info and help, i was confident the 260RS had the S3 RB26dett out of the R33 but its all about dump pipe's thread type also,
i didnt get a chance to ring my contact today as i was trying to sort out braided lines that didn't fit my brakes... any ways will give it a shot tomorrow
Cheers GW
The 260RS has the same sized thread as the R33 GTR. It is the larger 18mm thread. The R32 GTR is the smaller 12mm thread. I assumed that since the R32 GTR uses Titania sensors, then the R33 must also use Titania. I have been searching and going off what other forums have said, as well as the fact that the wires on the stock 260RS sensors are white/white/black it looks like the R33 GTR may actually be Zirconia. Prior to this group-buy I had already purchased some OZA395 sensors which I thought were wrong. I am going to try them this week (once the socket arrives) and I will confirm back to the forum if they work or not. Hopefully that will stop the confusion.
Simon
ok i rang for a price on the OZA395-E2
5x OZA395-E2 = $68.15inc
i also found out some new information that people may not of been aware of
Zirconia are made by Bosch
Titania are made by Siemens
now when the R32 GTR was built Nissan might of had a deal with Siemens for them to supply all there O2 sensors and when it came to the R33 they MAY have changed to BOSCH contract which would make sense as RB25 have zirconia why wouldn't RB26
the aforementioned statement are purely thoughts of my own and are not based upon anything ive read
my source tells me there is an easy check to see if your running Titania or Zirconia
unplug you O2 sensor and start your car measure the signal wire with multimeter and...
Zirconia should give a reading .3-.4 volts
Titania should give a reading of 3-5volts
Madaz, thanks heaps for that information.
I might have to give your test a try :) It makes sense, since the Titania sensor varies resistance (and requires a current flowing through it) and the Zirconia sensor varies voltage.
Last night I put my sensors into my Stagea 260RS. I can confirm that the sensors are OZA395-E2 and they work prefectly. Apparently the 260RS is identical to the R33 GTR. I'd appreciate if someone can confirm. I'm pretty sure they are.
Please see my notes in this thread:
http://www.skylinesaustralia.com/forums/O2...iew=getlastpost
Yes the 260rs is the r33 gtr engine
thats good news for r33 gtr owners cheers for that
chad and ruby will collect monies of you guys tonight
Hi there, just a headsup, sending dosh for 2 each of these suckers now.
Cheers GW
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
