hi guys
I have a alarm system and the remote doesn't seem to operate as it should.
thought randomly it works fine.
I assumed it was the battery, but when I replaced it it was still the same.
anyone have a rough idea of what may be the issue or is it simply the fact my remote is stuffed?
If there is anymore information I need to share to assist with someone helping me.
please let me know.
Regards
Sloane
https://www.sau.com.au/forums/topic/230330-alarm-remote-not-operating/
I have the smae problem wuth my remote.
I used to try changing the battery, I now just crack the shits and tap the remote on something...... lol not the best fix, but it makes me feel better :)
If any one knows a way to fix this issue,I would also be greatful for the information.
yeah mate had the exact problem with a customers car at work. pulled it apart and found two dry solder joints. resolder them and it worked like a treat. if you are good with a solder iron then give it a go cos if you take else where they will tell you to replace the remote.
Same god damn problem with me aswell!
Curse the previous owner who had to install a shitty eBay alarm grrr !!
Solder it aye? Hmm.
And what if that doesnt work lol ?
I played around with the 2 dials in the remote..
Didnt do anything for me.
MRXTCZ
Solder it aye? Hmm.
Don't touch it unless you have a back up plan if you stuff it up lol
I notice its been working fine when I point remote to engine direction :ermm:
I remember I've got a Spare Remote but its at a relatives so will have to pick it up.
I lurk on a huge list of forums, lol.
And your dead right, dont try to fix the remote if you dont have a fail-safe plan, that's just asking for trouble, and will put you into a bad situation.
With my previous car, someone installed a cheap ebay POS alarm, and wired it in quite stupidly, so I had the car towed (became unstartable) to an auto electrician and set him to task to remove the mess and set the car back to stock.
He did this, and then I went and got a proper alarm system installed in the car.
B.
  • 3 weeks later...
hey guys
stupid remote not working again
i tried my spare remote to see if it worked and didn't do anything either....
now I'm getting all sorts of weird beeping and basically have no friggin central locking meaning i need to open door via the key.....
and to start my car now I have to put key in ignition
set the alarm off then press remote to disable immobiliser and alarm (only time it seems to work)
just to start my car!!!! :sleep:
I'm going to ring the installers tomorrow who installed the alarm about the issues I'm having.
I got this installed on 25th January 2008
spent about $2200 at their workshop
Just curious as to whether they should fix this issue under a warranty?
Can some please verify that.
If all goes down the drain I will be seeing Chris Rogers.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
