didnt mean to make two threads. Was a accident. Yeh if i had the $$$ gold vork gtc would be the pick. Hey if i had the $$ in the first place then i wudnt be writing up this thread either.
added the black
also dont buy any rims that say "voRk"
as has been said... buy japanese... as in MADE in japan
