post-34523-1217585562_thumb.jpgLate 1990 GTR Extra Tidy Show quality paint, Well serviced, Low KLM 72000, 33 GTR Alloys, Tein suspension, Oil cooler, brake upgrade, new tyres & extra clean all round. Ideal for someone you doesn’t want to pay for re-spray or engine rebuild, hard work complete just enjoy
Hi Late 1990 32 GTR: Imported as personal import. I had a couple of guys looking for me in Japan with the brief of low klm, not thrashed and in excellent condition. One of the brokers that I got a couple of cars from previously had a family member that purchased a GTR from his uncle. I requested a Black Metallic one as well just to differentiate from the common Gun Metal Grey and rental car White. The car is still under 72000klm, I know you can’t always trust the klm but the odometer all lines up. Like anyone I go by the interior, compression, driveline and my mechanic always raves that it’s the tightest Skyline he has driven in years. Basically I didn’t want a car that had been thrashed that I would have to deal with the high maintaince costs and repairs, I have had huge bills before and I would prefer to pay the extra cash as it saves in the long run. * I am big on servicing and prevention and I give priority to having the car tidy.
Body & Paint: The car came over in good condition but like all cars it had lost its gloss. Being a bit fussy I got a complete respray as I wanted the car to be in show condition especially if I was going to be keeping it for a long time. I got a professional with a good reputation to complete the job as they do a lot of show cars. At the same time I got electronic aerodynamic side mirrors to modernise the car and the front lip painted to match the car. As well I got the guards rolled front and back to fit bigger wheels and tyres without scrapping and to allow the car to be lowered with coil over’s. * Under the car is extra clean with no surface rust or dings on chassis. I have previously seen a lot of imported cars with heavy marking from transport and jacks.
Suspension & Handling: I went TEIN for the lower control arms and for the coil over’s due to availability for maintanice in the future. I had the suspension guys set the coil over and alignment for street and touring. Overall it’s a tight set up for driving as a daily driver and for tight cornering. Polished front strut bar for stability. Extra Info: 1. removes the deflection at the joint from high cornering loads 2. Provides adjustability of the front track, giving greater clearance between the chassis and wheels (Only recommend 20mm per side) 3. Changes the lean angle of the front shocks by moving the front hubs outwards, reducing roll angles and effectively creating a camber increase
Wheels: I went the classic 33 GTR wheels that are pretty timeless and because I wanted genuine Nissan look. Unfortunately I paid for them when they where still expensive but they are worth it. For tyres I went the low profile Silica compound and they have only done about 2000klm very fresh and sticky.
Interior: We looked for a car that had not been lived in. I have kept it genuine even with the original stereo, pretty rare these day but it’s the only one that sits flush with out gaps. I had the interior steamed cleaned just too fresh it up. Overall the interior in great condition from what you would expect with low KLM’s. I have had the split controller hidden in the console with all hidden wiring.
Engine: Extra fresh engine to protect the engine the first thing I got done was a complete flush and then replaced the oil and flushed again. New oil cooler mounted in the front to maintain oil quality, reduce temperature & wear. Oil filter relocated fitted to make it easier to change filter and drain oil. Car has never been boosted as it’s not what I wanted when tracking it down or what I need. Split controller was recently fitted to enable different torque setting, very useful in the wet as it makes the car handle like its driving in the rain. The controller also enables the car to be switched from 4 to 2 wheel drive, HKS Air filters and extensions have been fitted. # Engine bay, as you can see from the pictures the engine bay is in great condition with not the usual scratches and dings. Instead of the boring flat black engine bay the engine covers have been sand blasted and painted with the Red 34 GTR colours.
Engine Servicing: Oil pressure sensor replaced &a full set of NGK Iridium plugs. Coolant flushed by Red devil Radiators & replaced with Genuine Toyota Timing Belts/Bearings Timing Belt Idler & Tension Bearing, Tensioner Spring, Cam Seals & Front Main Seal. Water pump. Nismo Reinforced Engine Mounts. By increasing the hardness of the rubbed used in the mount bush, it help to protect the engine from damage. Engine vibration is also reduced during acceleration and deceleration. Overall it improves accelerator response, shift feeling and cornering performance. Exhaust 3 inch Turbo back stainless exhaust with high flowed N1 catalytic converter.
Braking: Stainless steel brake lines to reduce wear and increase consistency. Upgraded front disks and new high quality pads all around. All Callipers have been painted 34 GTR Red to match engine.
Price $22950 Yes there are cheaper but you they are usually thrashed and will require engine rebuild, body work and paint to bring them up to scratch. Feel free to call and discuss. Regards Boyd 0408 188 777
Edited by GGG
Hi, I will consider trades plus majority cash my way. Cheers
hi
still for sale? where in brisbane is the car? has the engine been modified in any way and is the exhaust stock? might be keen to have a look but may be a bit above what i was hoping to spend. is the price negotiable? i am selling a 2003 vectra cdxi hatch 3.2 v6 manual if you had any interest in trade.
matt
hi
matt
Hi Matt,
Yeah still for sale I end up being out of town every time someone wants to look. I have kept the engine stock except for Oil cooler, pod filters, aftermarket computer. Split controller was recently fitted to enable different torque setting, very useful in the wet as it makes the car handle like its driving in the dry. Exhaust 3 inch Turbo back stainless exhaust, front pipes with high flowed N1 catalytic converter. Great note.
I am negotiable but not for any crazy drop, overall I do acknowledge there are cheaper GTR’s but they usually require paint, engine work and have high KLM
I am open to trades with cash my way.
Regards Taylor 0408 188 777
uummmm
by the way, top looking 32, but seriously man, sell your novel to a Publishing house and get a job in an advertising agency
uummmm
Ian thanks for taking me to school, I missed a full stop and it should read.
Genuine Toyota coolant. Well serviced replaced Timing Belts/Bearings Timing Belt Idler & Tension Bearing, Tensioner Spring, Cam Seals & Front Main Seal.
Cheers
hi
matt
Hi Matt
I forgot to mention based near Carindale or City for work.
Cheers
thanks, keeping it in mind.
Hi Matt
E-mail if you want any more pics as I had to take some for a guy on the weekend. goog luck with the sale of your car.
Cheers
Guys
Forgot to mention the car comes with Blue tooth car kit, Nismo Key and Blitz Turbo Timer.
Cheers
Pics are back on line, as requested
Guys
Cheers
Guys
Just droping a line to say I am back in town this week, as a couple of guys wanted to catch up in the last few weeks but I have been away. Call or text if you want to check the car out. Please note price drop in previous posts.
Cheers
Guys
Cheers
Hi
I have been off line, but I have now replied to PM's, I am in town this week except for most of Saturday heading down to speed on Tweed.
Cheers
Hi
Cheers
Please note price drop, $22450 Cheers
Hi, Guys that called during the car is available for viewing this weekend, best to cal on 0408 188 777
Cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
