we have just fitted my trust dump pipes on my r33 gtr and the rear 02 sensor is touching the turbo lines.
i dont want to put aftermarket braided lines
so my other solution would be to find a smaller 02 sensor but where can i find one?
or are there any other solutions appart from making another hole for the 02 sensor further down the dump pipe?
any help is really appriciated!!!
thankyou
Interesting that one
I used the R33 GTR O2 sensor, and it was fine with the Trust pipes and supplied fittings.
I believe R32 might have a height problem (i do know the screw is different size etc)
Are you sure you have not slightly bent the turbo lines somewhere?
Or maybe bend them out the way a few mm?
Mine were close, but not touching :(
A few mm of slow bending, is not going to damage the lines. Hell they would probably bend a bit just taking them off and undoing the banjo's etc.
Thats the best i have, but unfortunately the O2's are not in there at that state.
But it gives you an idea
There is a bigger pic in my gallery, it wont let me link the bigger version into the forum section
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
