haha one two many nismo things in my life. When you call your car niz, and people call you niz, calling you dog niz is a little overkill :( No to turbo as well.
She is a fast little thing - she gives Kaos a run for his money but she is also incredibly sweet and timid. Also obsessed with food - if she was male i would call her Ramsay! she is just incredibly obsessed with the kitchen and treats.
Edited by Nizmo
Nismo is a nice name for a dog :(
mate with a husky has already called his Nismo.
i thought all husky's were called Nanook
if his name is Kaos...she should be called Control...or 99.
Edited by DiRTgarage
haha yeah people at work have already suggested Control but i think i would die of embarrassment chasing a dog around the dog park calling Control.
I like: Rush
but i have a habit of naming my dogs weird things so i've given the choice to paul who has then handballed it back to me.
Spiral - you sound like the girl in the park that suggested "Sparkle" :P
Kinda come to a decision on Rogue. Like from the X-men because she has the 'patch' round her neck that Kaos doesn't have.
Bernard - Your more than welcome to use them as the wallpaper :banana: They are a pretty cute pair!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
