Make:nissan skyline 1991
Model: r32 gts-4
Milage:120,500
Transmission: manual gtr conversion
Colour:red
Complied?yes
RWC supplied?no but its not defected eather!
Currently registered?[/bno]
Price:$4,000
Contact:0403847120
Comments / Modifications:exhaust
Images:yes
Model: r32 gts-4
Milage:120,500
Colour:red
Complied?yes
Price:$4,000 or best offer!
Contact:0403847120
Images:yes
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 4 weeks later...
  • 5 months later...
