1990 Nissan Skyline R32 GTR
Twin Turbo RB26 4WD
52,000kms on Aftermarket Dash
Fresh Engine Rebuild with Stock Bottom End done 1500km.
New Rings, Conrod Bearings, Steel Head Gasket, Timing Belt, Water Pump.
Remapped Computer by RS Yamamoto in Japan
R34 6 Speed Getrag Close Ratio Gearbox
GARRETT 2860 Ball Bearing Turbo's
650cc Injectors
WALBRO Intank Fuel Pump
BEE R Stainless Tuned Length Front Pipes
New Stainless Exhaust Manifolds
Stainless Dump Pipes
3 1/2" Stainless Exhaust
3 1/2" Stainless Cat
Japan Drag Racing Association TRUST Muffler
Adjustable Cam Gears
Ported and Polished Head
OS Giken Triple Plate Clutch
N1 Oil Pump
TRUST Oil Cooler
GREDDY Intercooler with Water Spray
HKS Intercooler Piping
17" x 9.5" BBS LM Wheels
Front Brembo Brakes
2 Piece Slotted Rotors
Braided Brake Lines
Remote Oil Filter
Aluminium Triple Core Radiator
BOSO Coilover Suspension
Recaro Seats
6 Point Roll Cage
Rear N1 Lip
IMPUL Front Lower Lip
Front and Rear Strut Braces
CUSCO Adjustable Rear Uper Arms
Adjustable Front Castor Arms
V-Spec Underbody Chassis Braces
Heavy Duty Sway Bars
MS Angle Intake Pipes
K&N Air Filters
MINES Air Flow Meters
GREDDY Profec Electronic Boost Controller
GREDDY Turbo Timer
TOMEI 310km Dash
GREDDY Oil Pressure, Oil Temp, Water Temp, Exhaust Temp and Boost Guages
SPARCO Steering Wheel
2WD/4WD Switch
Makes 400rwhp on 1 Bar, 450rwhp on 1.2 Bar. Very Safe and Reliable.
Plenty more potential with an Aftermarket Computer.
Feature Car for Upcoming High Performance Imports Magazine.
$35,000 o.n.o.
0400696678
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
