Just got a darty new car,
not a skyline and it not turbo,
i got it free and it has no rust and is straight :thumbsup:
gonna clean it and do some skidskidskid with the mega powerful 253 blue motor putting out a neck breaking 80kw
planning to put a 308 or 350 and use it to tow the 32 and tyres to the track
https://www.sau.com.au/forums/topic/231163-new-project/
Congrats for getting off your P's
And 12th car :banana: Thats nuts. I've had my license for 7-8 years and I'm only onto my 4th lol
yeh but im gonna settle now coz out of 12cars im happiest with the r32 :P the WB ute will just be a slow restoration with the gf
https://www.sau.com.au/forums/topic/231163-new-project/#findComment-4061488
So do you skidskidskid at home sam? since you got a pad and all??? im interested in gettin in2 the sport and also got a r32 but just bought a house so wont be straight away, maybe i can come and learn at your place :P jkz
yeh maybe, sometime thinkn of organisin for lota ppl to come do skids but havnt had a chance
Edited by sidewayssam
https://www.sau.com.au/forums/topic/231163-new-project/#findComment-4062240
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
