Make: Nissan
Model: R32 GTR
Milage:65,000km
Transmission:Manual
Colour: Gun Metal Grey
Complied? Yep
RWC supplied? N/A
Currently registered?Yep
Price:$25,000 ono
Contact:0417 969 161
Comments / Modifications:
ENGINE and DRIVE TRAIN:
Sydney Kid RB26 build including:
Forged Rods/Pistons
600HP Head work
Stainless Steel Exhaust Valves
Adjustable Cam Gears
Balanced rotating mass
N1 Oil Pump
Sump Extension - Extra few Litres with full baffles
HKS 2530 Turbos - the real McCoy!!!
700cc 12A Turbo Injectors
80mm AFM's
Power FC
K&N Filters
HKS Billet Flywheel
Jim Berry clutch
Full Redline Racing oils front to back
SUSPENSION
Full Sydney Kid Bilstein set up
Billies front and rear
King Coils
Whiteline Sways
Bush Kit
Camber Caster adjustment etc...
WHEELS
17" Sparco Racing 5 Spoke rims
New Rubber all round
OTHER STUFF
Slotted Brake Rotors
Mandrel bent exhaust - Japanese.. can't remember the brand...
Alpine stereo - MB Quart splits up front and two ways in the rear. 10" Graphite Sub - Eclipes Amp
Interior is in MINT condition
Full DEFI Link Guages - Exh, Oil Temp, Water Temp, Fuel Pressure.
Front Strut Tower Brace
New Radiator
Iridium Plugs
Engine has done about 5,000 km since rebuild. Genuine reason for sale... I have 5 cars (6L Torana, Prado, Lexus V8 Hilux, Nissan Patrol and the GTR) Something has to go. I've spent a fortune on this thing and it doesn't get driven much. I figured that someone should be enjoying it... Classic story of spending a cr@p load of money, then selling it for about half what it cost. Runs great. Never misses a beat... sorry to see it go... Shed a tear with me guys.... ;)
I have a heap of photos' for those interested, including photo's of the pistons and other parts to those that need proof of what the rig is made of...
Images:
https://www.sau.com.au/forums/topic/231574-r32-gtr-for-sale/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
