Just wondering if you guys could help with a few niggles with my current PowerFC setup.
Car - R33 GTR , HK GTSS Turbs, 700cc Injections, Tomei 260/260 Poncams - fairly late model PowerFC
Cold Start on PFC
- On a cold start it idles at 1700 RPM
- then settles down after it warms up a bit to idle at 1100 RPM
Hot Start after a short stop
- Idles at 900 RPM
Hot Start after waiting for 1-2 hrs (engine still warm)
- Hunts from 800 RPM to 1300 RPM or so
Any ideas?
SHould I have a play with the cold start settings on the PFC? Advice?
Cheers,
Thanks
https://www.sau.com.au/forums/topic/231575-powerfcgtr-coldwarm-start-issues/
Always pretty much revved high since the last tune - what would be normal ? . The warmed up idle is fine and also when it is started when the engine is still hot. I could not even tell you when the warmish start hunting started because I normally just drive to & from work (only about 5 minutes) & for quick stops. There is not that many occassions where I would have the car really warmed up & then leave it for a an hour - thats when it hunts - it does settle down after a few minutes as it warms back up to the full operating temp.
Thanks
P.S. I do have datalogit & have the map downloaded so I could have a look at that.
Edited by Penfold
well if you have datalogit then warm the engine up, get the water temp to near 80deg
save the tune, perform a data init and redo the self idle adjustement procedure
make sure the idle is stable (test it properly) once done and then load the tune back on
this should clear away any idle issues
before you ask, its in the PFC FAQ in my sig so read that on how to do the self idle adjustment correctly
if you dont do it or properly or skip parts of it you end up with a hunting idle
OK cool I will do that . Also when I checked under the Function Select:
Boost Control - Disabled
Ign/AirF Warning - Disabled
Knock Warning - Enabled
O2 F/B Control - Disabled => but I enabled it
O2 Sensor Reg - Disabled
Should I change any of them too?
Ok,
I'm gonna do it - but wanted to check a couple of things.
Heres a copy of the map that was done by the tuner: Datalogit Map R33 GTR
Going by the date that was at the start of the year. However that map would have just been downloaded cold - not at operating temp
Will it yield a different map if it is downloaded before operating temp is reached.
Is there any settings that won't be in that map file that I should record as well? eg inj %, function settings?
Sorry for all the questions - just don't want to lose the tuned map.
Thanks again,
Pen
02 f/b control I understand what that is, but what does o2 Sensor reg do?
Do you need it on or off for 32 or 33's?
I didn't see it in the paul's pfc manifest when I last looked either.
02 REG is needed for BNR32 owners
as the PFC unit for BNR32 and BCNR33 is the same unit but the BNR32 has titania 02 sensors and BCNR33 has normal 02 sensors.
the BNR32 needs to be set as registered to make them work as titania sensors properly. Otherwise with it off the PFC assumes they are BCNR33 style 02 sensors.
This is covered in the FAQ
apexi's official answer;
There is a difference in the O2 sensor for these vehicles. (With or without internal register)
After tuning, please check () "O2 SENSOR REGISTER" for BNR32, and NOT for BCNR33.
* It may be different if the O2 sensor is modified and/or changed.
Ok, thanks for the reply.
I only looked in the faq listed in your sig, thinking it might be easier and more relevant than swimming through 22 pages (and 437 posts) of thread.. which I didn't remember existed anyway..
Sorry again,
But I came across another question.
In the Datalogit map it stores the Rev/Idle limits, function selects, injector settings ( 85,85,85,85.5, 86,86.6) as well the various water temp/air temp corrections.
So I thought I would need the injector seettings put in if I reinitialzed & did the reinitialize procedure - is there anythign else I should add. Also if I did it & copied the tuned .dat file back across it will overwrite all the data - so I should just keep the different temp correction stuff and overwrite everything else?
What I will do this mornign is hook it up & record a log file for the cold start procedure itself and a warmed up start & a warmish start - which settings should i make sure I log - or just all of them?.
Thanks,
Pen
Not sure, can't find any leaks. I think it might be due to the temp correction or sensors.
Here's the logs:
http://members.iinet.net.au/~ptv/penfold/l...ntingatidle.dat
http://members.iinet.net.au/~ptv/penfold/l...ntingatidle.txt
http://members.iinet.net.au/~ptv/penfold/l...ldcoldstart.dat
http://members.iinet.net.au/~ptv/penfold/l...ldcoldstart.txt
I'll get up a really cold start where it goes up to 1800 RPM at idle.
Cheers,
Pen
Ok,
Just to clarify a few things:
a) The map (.dat) file I downloaded at cold/warm/hot starts were all the same
b) The Self idle adjustment procedure does adjustments to settings that aren't found in datalogit (so copying data back on won't wipe the self-learn?)
c) I put the Injector settings, disable boost control in first after I initialize.
d) I leave the ingition/water temp correction settings as they are?
e) I do the initilizae at an absolute cold start?
Thanks again,
Pen
my mate had a few problems with the power fc and idling etc..., i then read in some imports mag or something that this is a common problem with power fc is the idle control on it isnt that good, and using different turbo's and cam etc can stuff up the idle, they suggested a hks idle stabilizer, i think they cost like $150 or something, and that way you can set up what voltage you want it to send etc. so if you car is only reading enough voltage to make it idle at 750-800 you can make sure that a voltage wont go below a certain amount so it will only drop to 1000, if that makes sense, anyways have a look at it on nengun or something, that might help you out,
JV
Hmm,
Redid the initialize but now it seems to hunt more than before ( I did it from an absolute cold start & just added inj % & disabled BC ). It does have to be started from absolute cold start right ? Then I copied the tuned map back over the top.
Ok,I will redo the initilize procedure again tomorrow morning unless theres some other suggestions? then I'll copy the map it comes up with & post it up. Then I will copy the whole tuned map back over.
Any tips?
Cheers,
Pen
the self idle learn procedure is covered in detail in the PFC FAQ
you should read this before wasting any more time
be sure to note
30 minutes must be set aside for it
the engine must be warm (80deg water temp)
you must not fiddle with the car (if you tap the throttle forget it, start over)
do the demister, aircon etc in the correct order and for duration
if you are unable to get a stable idle there are some additional things you may need to do based on your engine
if it doesnt idle properly you might need to adjust your AAC valve to let in more air to make it idle (ie : larger cams)
the apexi documentation states this
lastly - get a tuner to do it if you still cant sort it out
for %99.999999 of the time the out of the box idle works on almost any car, even cammed
Awesome. The learning map at cold start explains why its all over the place now - i will correct tomorrow
Because I live in Bundy and nearest 4wd tuner is 4 hours way its hard to organize - its been tuned already but as I said initially - its the cold startin revving high & the warmish start hunting - probably did not get noticed in the initial tune
So checking what the usual corrections are to cold start to reduce idle & secondly for the warmish start to boost the idle RPM revs. Using datalogit there are a heap of correction tables but I was wondering what the usualy procedure is from someone who has modified these settings before.
Thanks heaps - its just a couple of bugs I was trying to iron out.
Also, I will eventually get it to tuner again - its just that the warmish & absolute cold start take days to duplicate on a regular basis to tune it out & I don't have the opportunity to leave the car in brissy for a number of days.
Edited by Penfold
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
