before june is early??
Have a look at the ECU (pull up the bit covering the passenger step and take off the cover in theLH footwell). Mine is numbrered 23740 OV300 which i think is the early, more common one.
are you talking about my ECU saga? http://www.skylinesaustralia.com/forums/R3...S1-t205298.html
yes the v10 ECU is the same as mine, so you will have challenges with the wiring. but as I said in the other thread, talk to Mark at Hills Motorsports, he has a pretty straightforward solution to run r34 gtt PFC in it. very good result compared to the standard computer.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
