Hey Guys,
I had to remove my backseat, to get my parcel tray and 6x9s out of my car so that the rear window can be tinted. At the moment im driving my car around with no backseat. Is this illegal? can i be defected or anything like that?
Obviously no one is sitting back there, but i ama bit concerned it i get pulled over.
Cheers,
https://www.sau.com.au/forums/topic/231766-legal-o-not/
Nah its not.. as long as you've still got the 3 belts in the back then its fine.. I got pulled over a few months ago with no back seat and the HWP guy didnt mention anything about it.
Previously I've been pulled over with a metal bar mounted across the back seat (vid camera mount), and the cop said that if I want to keep it there i've gotta re-engineer the car as a two seater because its not safe for people to sit back there with the bar there. The back seat is just comfort/padding so I cant see why it'd be illegal to have it removed.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4068951
You do know they can tint your windows these days without having to remove your backseats and parcel tray..
It's amazing what they can do these days!
They have been doing this for years :O
yea i always wanted to know if you could get defected for no back seats.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4068973
Maybe his 6x9's are mounted on spacers which locate them close to the rear window almost touching.
I had to remove my 7x10's for rear window tinting as mine pretty much touched the rear window.
Dude,now that you got the speakers out,just throw the backseat back in if your worried(i would be)
On a r32 its just 2 or 3 clips and 2 bolts.
EDIT: spacers,i knew it!
Edited by FATAZZ
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069007
speakers sat to high up... almost rubbing on the window... you know spaces and all? Amazing what people assume...
Oh and thanks for the info... is good to know.
Well if someone else is doing it.. Why don't you let them worry about the problem. That's what you are paying them for.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069018
Because im a bit tight and didnt want to pay extra for them to do that. also didnt trust them taking everything out without breaking anyhing.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069030
it is illegal unless the car is registered as a 2 seater even if the seat belts are still there, ive been defected a few times for it on the way back from the track
Edited by reaper
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069585
hang on now i'm confused. when i took my back seats out to install my stereo, i made some enquiries and called a place to get an approved certificate, and they asked, what part of the body am i changing? and i replied with nothing, i'm just adding MDF and fibreglass to the back and they said it was fine. my seat belts are out, my rear pillars have tweeters in them, and nobody has ever said anything...?
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069647
This is correct.
Im pretty sure its a red defect and carries points (2 or 3) if you take out your rear seat belts even if no one is in the back seat..
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069897
^ Totally agree with the above.. Illegal unless registered as 2 seater..
Prevents fully sick drifters driving around with stripped out cars.
doesnt prevent it just requires money spent on a blue slip for it to be legal
removing rear seats gives me alot more room for tyres its not just about making it lighter :thumbsup:
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4070145
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
