Hey Guys,
I had to remove my backseat, to get my parcel tray and 6x9s out of my car so that the rear window can be tinted. At the moment im driving my car around with no backseat. Is this illegal? can i be defected or anything like that?
Obviously no one is sitting back there, but i ama bit concerned it i get pulled over.
Cheers,
https://www.sau.com.au/forums/topic/231766-legal-o-not/
Nah its not.. as long as you've still got the 3 belts in the back then its fine.. I got pulled over a few months ago with no back seat and the HWP guy didnt mention anything about it.
Previously I've been pulled over with a metal bar mounted across the back seat (vid camera mount), and the cop said that if I want to keep it there i've gotta re-engineer the car as a two seater because its not safe for people to sit back there with the bar there. The back seat is just comfort/padding so I cant see why it'd be illegal to have it removed.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4068951
You do know they can tint your windows these days without having to remove your backseats and parcel tray..
It's amazing what they can do these days!
They have been doing this for years :O
yea i always wanted to know if you could get defected for no back seats.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4068973
Maybe his 6x9's are mounted on spacers which locate them close to the rear window almost touching.
I had to remove my 7x10's for rear window tinting as mine pretty much touched the rear window.
Dude,now that you got the speakers out,just throw the backseat back in if your worried(i would be)
On a r32 its just 2 or 3 clips and 2 bolts.
EDIT: spacers,i knew it!
Edited by FATAZZ
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069007
speakers sat to high up... almost rubbing on the window... you know spaces and all? Amazing what people assume...
Oh and thanks for the info... is good to know.
Well if someone else is doing it.. Why don't you let them worry about the problem. That's what you are paying them for.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069018
Because im a bit tight and didnt want to pay extra for them to do that. also didnt trust them taking everything out without breaking anyhing.
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069030
it is illegal unless the car is registered as a 2 seater even if the seat belts are still there, ive been defected a few times for it on the way back from the track
Edited by reaper
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069585
hang on now i'm confused. when i took my back seats out to install my stereo, i made some enquiries and called a place to get an approved certificate, and they asked, what part of the body am i changing? and i replied with nothing, i'm just adding MDF and fibreglass to the back and they said it was fine. my seat belts are out, my rear pillars have tweeters in them, and nobody has ever said anything...?
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069647
This is correct.
Im pretty sure its a red defect and carries points (2 or 3) if you take out your rear seat belts even if no one is in the back seat..
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4069897
^ Totally agree with the above.. Illegal unless registered as 2 seater..
Prevents fully sick drifters driving around with stripped out cars.
doesnt prevent it just requires money spent on a blue slip for it to be legal
removing rear seats gives me alot more room for tyres its not just about making it lighter :thumbsup:
https://www.sau.com.au/forums/topic/231766-legal-o-not/#findComment-4070145
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
