Item: Mines stainless steel dump pipes
Age: Used
Condition: Excellent
Price: 600 ONO
To Fit: (What car) RB26DETT
Contact: PM
Comments: Will post pictures and measurement tonight. Very rare and expensive RRP with proven power gain. Good for 400+rwkw
Item: Mines Front Pipe Pro Stainless with black ceramocoat
Age: Used
Condition: Excellent.
Price: 700 ONO
Contact: PM
Comments: Awesome sound. This pipe has 2x 70mm outlets combined into the single 80mm outlet. http://www.rhdjapan.com/jdm-low/MINE-s-Fro...line-GT-R-11747
Mines Motorsport badge was removed by ceramic coating place for optimal coating :happy:
Item: Custom dump pipe for greddy turbo with ceramic coat
Age: Used
Condition: Has black ceramic coat
Price: 250
Contact: PM
Comments: These pipes were used with the Mines extension pipes when my high flow N1's were replaced with the Greddy T517z's. They were made specifically for the Greddy turbo to accommodate for the reverse wastegate swing. They were good enough for 400+rwkw on a RB26
Will post pictures asap
All PMs replied.
The Mines dumps are still available.
I am still waiting for reply from R34kid on the Mines Pro front pipe.
The custom dump is on hold atm
If you check the cost for ceramocoat you will realise that I my asking price are ridiculously low lol
I am on leave from work at the moment and I am just keen to clear some of these stuffs out of my shed
Sorry guys been flat out at work,
can you please post up a pic of the underneath of the front pipe also. I will check again on here first thing tomorrow morning, as long as it is not bashed at all underneath I will flick you through an offer.
Also can you confirm that the longer of the two pipes, the one that goes to the front turbo is not dented behind the other pipe, it could just be a shadow on the pic
BTW I got a quote for the coating at $125 from Jet Hot.
cheers
Edited by R34kid
R34kid, that quote is really cheap. I just coated my other dump pipes by Competition Coating in QLD and the coating for those 2 short pipes costed $280 :(
I will take some mores pics tonight. The above setup were big enough to flow 2 largest low mount Greddy turbo on a stroked RB engine so I wouldn't worry about restriction :P
I am uploading more pictures of the front pipe now. That black thing on the picture is a shadow as I took the picture late last night. There isn't any dent around there. There is small dent on the under side but is only minimal and is expected for a lowered car :D You will see in the pics shortly. Overall the pipe is still in good nick. It's has a 20cmx8cm pipe and two 80cm by 7cm tuned pipes. R34kid, if you can still get both side black ceramocoat for $125 please let me know so I can send stuffs to Jet Hot for coating in the future.
Edited by 9krpm
wow that is nasty, Jet Hot said $60 per metre at 80mm diametre, for black ceramocoat - they also do stainless finish ceramocoat which would be pretty sweet
hmmm that is a really good price for heat coating. Thanks for the referral :P
So, do the mines dumps fit a pair of T517z's or was that only the custom ones you had?
The Mines dump pipes were designed for Garrett turbo. As far as I know they don't have dumps for Greddy. You will either have to use the Greddy or custom because the Greddy wastegate hinge is on the reverse side of the Garrett.
I am selling a set of T517 so the custom dump is reserved for the turbo buyer. If the buyer refused to take the offer then it's available on the market. Sorry for any confusion.
All good, no confusion... I just thought it might have been an option before i go buy a pair of tomei dumps instead, or nismoids's trust split front pipes.
If you have trust turbo, the tomei dumps won't fit either.
Sorry correction, they all fit but the back of the dump will get in the way of the waste gates. So they may not open fully or get jammed up on the dump :~
Edited by 9krpm
  • 4 months later...
