Make: Nissan
Model: 1990 R32 GTS-T
Milage: 120000
Transmission: Manual
Colour: Black
Complied? Yes
RWC supplied? N/A
Currently registered? Yes, untill May 2009
Price: $11 000 ono
Contact: 0433359900 (call after 4pm weekdays) (will accept SMS all day)
Comments / Modifications:
This is my Black R32 GTST i am selling, healthy modifications listed and this car will not dissapoint.
Car is reguarly serviced, and looked after, car also comes with orginal log books and manuals,
This is a nice tidy car, never a dissapointmant to drive, always fun.
Car also comes with spare parts:
-Front Guard (Can organise spraying before sale)
-Door with window and side mirror
-Boot lid
-random trims
-A few Blow Off Valves
-Front Bar (Without Cut out to fit Front mount)
-R32 Badge (From a Volkswagen Golf NEW)
Also car is getting a new Waterpump, Rocker Cover Gaskets and Clutch in the next week or two.
All Offers considered, Plese call after 4pm on weekdays, or i will reply to SMS's during the day, Or call anytime on tha weekends.
Can organise to meet people for a look at the vehicle and test drives.
Please no time wasters or joy riders
Thanks
ENGINE
-Front Mount intercooler
-HKS Electronic Boost controller
-3inch Cat Back Exhaust with cannon muffler
-Turbosmart Dual-Stage Boost Controller
-Apexi Super Intake Pod Filter
-Walbro Fuel Pump
-HKS Super Sequentail Blow Off Valve (Have others if wanted)
Suspension
-GAB Racing Coil Overs All Round And Fully Adjustable
-Pineappled Rear Solid Cradle Bushes
Interior/Other
-Tomei Steering wheel
-Pillar mounted Phantom Boost Guage
-Greddy Pllar Moulded Guage Pod
-Clarion CD Player
-R32 Badge (rear)
-De-Badged Front Guards
-Tinted Windows
-Remote Central Locking, Alarm and Immobiliser
-White 32GTS-T wheels x4
-3 Piece Zimber 17 inch Wheels, Black, x2
Don't know how to upload photos to this as of yet, Can send via email or some one could post them up for me.
Thank You
https://www.sau.com.au/forums/topic/231825-r32-gtst-for-sale/
why 2 boost controllers? it aint hardt o up load pics click browse at the bottom of you post set up, get the pics off you comp then click upload after each pick is chosen!
Ok new clutch is in, car goes awesome.
Also i have found my new car and really need to sell tha skyline, soooo im droppin tha price to $9000 ono.
call or pm me for any other details
Make an offer if you want, i want to hopefully part with this car in the next week or two as i have found my new car.
Pm me and offer and ill go from there, im in NSW by the way, located in the shire (cronulla area)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
